flywheel problem , I have a problem with a vibration with my 300 6cy . Bought atruck not running . got it running when reeving engine horrible vibration . I think the flywheel is in correct the numbers on it are C7TE-A . My local auto store is not much help.
C7TE-A looks to be a 289 V8 28oz external imbalance flywheel.
300-6 engines have a 0 imbalance. (No imbalance)
Both types have the same crankshaft and clutch plate mounting holes.
U have the wrong flywheel which will definitely vibrate badly and damage your engine if used.
Yesterday, the OP typed this question in the Large Truck forum, I gave him all the info there.
It's the wrong flywheel as you said, as it's for 1966/68 Bronco 289, 1969/77 F100 & Bronco 302, 1975/77 F150 302.
OP has a 1967 F100 w/a 300 I-6 & 11" clutch. I gave him the correct part number, found one NOS and told him it's probably available at auto parts stores.
