The StableLoad Challenge -- See what hauling 2,800 pounds will do to a 1/2 ton truck’s suspension
By the appearance, it may be easy to underestimate the performance effects of the StableLoad suspension stabilizer. However, the StableLoads are endorsed by many truck camper manufacturers including Northwood Manufacturing/Arctic Fox due to its ability to reduce sway and body roll, providing a much safer experience while hauling or towing.
To put this product to the test, Torklift International kicked off the StableLoad Challenge national event during Lance Owner’s annual rally in Lancaster, California this past September.
Here’s how it went down.
About the competitors:
Two identical Ford F150 trucks loaded with 2,800 pounds of gravel in the bed. The weight is intended to simulate the effects of hauling a heavy load such as a truck camper or towing a trailer.
What’s the secret weapon?
One truck had factory suspension while the other had the StableLoad suspension stabilizer installed and engaged.
About the challengers:
All of the test drivers haul campers and tow trailers with their trucks. Many of these drivers have had experience with other suspension alternatives such as sway bars or airbags. Even when airbags and sway bars were installed, common complaints were side-to-side sway, bounce, and the inability to transition back to their factory ride when not hauling or towing with their rig. Lucky for them, they were about to experience first-hand how the StableLoads can solve these suspension problems.
The outcome:
It didn’t take much for test drivers to see and feel the difference that StableLoads make on the Ford truck’s suspension.
Just by looking at the loaded trucks side-by-side, it was easy to indicate which truck was without the StableLoad, as it had significantly more sag than the other vehicle.
When the challengers drove the truck with the StableLoads engaged, they felt a significant improvement and noted the following characteristics:
- Improved overall handling of the truck
- Increased stability -- Prevented sway, body-roll and porpoising effects
- Significantly reduced braking distance
To view the full results of the test-drive and see how a suspension upgrade may work on your truck, visit Torklift's company blog for more information:
LINK - See what hauling 2,800 pounds will do to a 1/2 ton truck’s suspension
__________________
Torklift International – Towing, Suspension, Tie Downs, Steps
Call me direct: 1-800-246-8132
Visit our Blog: http://www.torklift.com/blog
Torklift Sheryl
Vendor Specials, Discounts, Product Announcements & Group Buys
03-19-2019 02:54 PM
Torklift Sheryl
09-12-2017 03:18 PM
Torklift Sheryl
05-15-2015 11:43 AM
Torklift Sheryl
03-27-2015 05:21 PM
