flathead distributor installation
Old Jan 5, 2015 | 05:51 PM
bubbatay's Avatar
bubbatay
Newbie in need of some direction. I just got back a 239 flathead that I had rebuilt and need some assistance installing the distributor. Do I just align the timing pointer to the timing mark on the pulley and install the distributor with the rotor pointing at #1 on the distributor cap.
Old Jan 5, 2015 | 05:55 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yep, same as for any other engine (pretty much), but you have a 50-50 chance that without further checking, you are at TDC on the exhaust stroke. If you have the #1 plug out, you can crank it over with your thumb over the plug hole; when it blows your thumb off the hole, that's compression stroke TDC. You'll likely have to back it up a ways to get the marks aligned. By the way, the marks are actually at 3 deg BTDC, which is where the timing gets set at idle with the vacuum line disconnected.
rlh68050
Aug 17, 2019 06:19 PM
dogmantra
Oct 4, 2010 12:43 AM
btacarlton
28
Apr 17, 2009 09:40 AM
ErrorS
Nov 7, 2007 07:04 AM
Narwhal
Apr 19, 2005 11:21 AM
