Need a Radiator
Old Jan 4, 2015 | 05:21 PM
Olaf65's Avatar
Olaf65
Need a Radiator
Core support is 65 and in nice condition. I do not want to cut it up making one fit. I hear the 73-77 will fit but which one will be a bolt in? Will the rad brackets need to be reversed? Are small mods needed to make one fit? Engine is 390 with manual shift. Thanks.
Old Jan 4, 2015 | 05:45 PM
willowbilly3's Avatar
willowbilly3
6 or V8? 2wd or 4wd? Needs to be same as your application. Not sure if 65 is same as a dent, doubt it though.
Old Jan 4, 2015 | 06:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
I-6 radiators different than V8 radiators.
1966/79 radiators will interchange (except 1967/79 Super Cooling radiators), but have their mounting flanges in a different location than 1965 radiators.
1965 F100/250 2WD & 1966 F100 4WD radiator support is the same. But it's not the same as any other year/model radiator support.
Old Jan 4, 2015 | 07:21 PM
Olaf65's Avatar
Olaf65
Thank you Sir, that was the info I needed.
Old Jan 5, 2015 | 01:37 AM
customcab66's Avatar
customcab66
i have a 65 core support on my 66 2x4 with 390 and the radiator out of a 76 because the core support I had is just like the one in my dads 4x4 the radiator set inside the mounts in stead of being flush mounted to the radiator
AlsRyd66
28
Jul 10, 2025 03:33 PM
664x4drvr
Feb 14, 2019 06:47 AM
jammeyer
WTB - Parts & other
Jan 7, 2015 01:13 AM
Dbass1292
Jul 11, 2013 02:51 PM
gangstakr
17
Jan 18, 2010 09:02 PM
