High Idle
Old Dec 30, 2014 | 12:14 PM
jaykappy's Avatar
jaykappy
High Idle
Hello
I have a 1997 Ford Ranger XLT 6 cyl. 4 wheel drive
I got this truck from a friend. Only had it for a month or so has about 185K on it but has been running great.
I did notice a couple times that when I pushed the clutch in approaching a light the truck would jump a bit in RPM to about 2600. but go back down in a second or two.
This started to occur more frequently and now it does it almost all the time....when I push clutch in it revs up to about 2600 RPM.
NOW I can have my foot on the brake and let the clutch out to put some strain on the engine and knock the RPM down but its still a bot high in the 1k range. Sometimes it actually goes back to normal...
When I started it this morning it was fine....but after two shifts it started and lasted the 12 miles to work.
Any ideas what could be causing this? It does not seem to go above 3000 RPM when it revs....
Other then that the truck runs great.
Thanks for your attention and have a Great New Year
Old Dec 31, 2014 | 08:20 AM
jaykappy's Avatar
jaykappy
I am thinking it may only be linkage....
I can slam the throttle down in gear and with the clutch in and it seems to knock the idle down. Just wondering if you all have any other thoughts?
Happy New Year
Old Dec 31, 2014 | 08:29 AM
pawpaw's Avatar
pawpaw
Welcome to FTE.
An acting out IAC = Idle Air Control deserves to be on your idle woe suspect list, as its a common problem part. You might consider trying removing & cleaning it internally with a swab & plastic safe spray, like CRC, or Valvolene MAF spray cleaner & see if you get positive results. Cleaning may not last, it didn't for me on my 99 Ranger & is probably why Ford recommends replacing rather than cleaning, but cleaning was a good trouble shooting step for me, before I replaced mine with an online discounted/promo code BWG mfgr one, from Advance Auto, about 7 years ago.
BWG = Borg Warner, they make a number of OEM parts for vehicle mfgrs, so quality is likely to be better than a no name off shore part. Of course the Motorcraft part is good if you can come by it at a good price.
Some thoughts for consideration, let us know how your trouble shoot goes.
Old Jan 4, 2015 | 05:09 PM
jaykappy's Avatar
jaykappy
Thanks...any ideas or scematics where this part is located? will try that first
Old Jan 4, 2015 | 05:51 PM
pawpaw's Avatar
pawpaw
Not sure which 6cyl engine you have, but the Tech Info page located atop this forums index page, or the forum search function is your friend. If you have the 3.0L Vulcan engine, you might be interested in these under hood component ID photos. https://www.ford-trucks.com/forums/5...locations.html Let us know how your trouble shoot goes.
Old Jan 6, 2015 | 07:14 AM
97ranger xlt's Avatar
97ranger xlt
a bad pcv valve will cause a high idle and not throw a code
rvborgh1
Aug 10, 2019 06:25 PM
imsorope
Oct 5, 2010 06:31 PM
gtrplyrguy
Nov 4, 2004 07:36 AM
mikeroo
Oct 12, 2004 05:12 PM
junior964
Aug 17, 2003 01:47 PM
