What transfer case do I have?
Old Dec 29, 2014 | 08:50 PM
GaRedneck91's Avatar
GaRedneck91
I have a 75 f100 4x4. The lever reads 2wd all the way forward then 4wd pulled back. That is how I always have locked in the 4wd. There is no hi or lo? It has the np435.
Old Dec 29, 2014 | 08:53 PM
Old Brown Truck's Avatar
Old Brown Truck
I think I've read that a Dana 20 (found in some jeeps and early broncos I believe) don't have a high/low range
Old Dec 29, 2014 | 09:30 PM
rockittsled's Avatar
rockittsled
Have you figured out what the gear ratios are in your axles yet?
Old Dec 29, 2014 | 09:55 PM
jswartz84's Avatar
jswartz84
Sounds like a dana 20. You might have to pull back a little harder to hit N and the 4 Low.
Old Dec 29, 2014 | 10:04 PM
GaRedneck91
Not yet I ain't got out there and messed with her since being out for the holidays. Hopefully this weekend for sure. So you think I do have a 4lo? What's the the gear seletion? 2wd 4 hi N then 4lo?
Old Dec 29, 2014 | 10:45 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Full time 4wd transfer case that is probably a New Process 203.
NP 203 **** on left , NP 205 **** on right
Look at the front edge of the transfer case for a silver blue tag.
I do not think its a Dana 20...?
Old Dec 29, 2014 | 10:46 PM
Montecz's Avatar
Montecz
I had a 75 like that about 25 years ago, if I remember right it had a dana 21 transfer case, they have a real thin case to them that liked to crack. I replaced it with a 205 after mine broke in half. I believe that there was just 2wd and 4wd in that one
Old Dec 29, 2014 | 11:15 PM
GaRedneck91
Are dana 21 worth a flip?
Old Dec 29, 2014 | 11:27 PM
Montecz's Avatar
Montecz
Not in my experience, the 360 and 435 that were in mine were enough to split it in half and drop half of the case on the road.
Old Dec 29, 2014 | 11:32 PM
GaRedneck91
Is the shift pattern 2wd all the way forward then 4wd is pulled back?
Old Dec 29, 2014 | 11:35 PM
Old Brown Truck
Old Dec 29, 2014 | 11:43 PM
Montecz's Avatar
Montecz
If you are going change it out I would recommend a NP205 they handle about any kind of abuse that you can throw at them. I had a NP203 they are okay but if you put too much power (for instance a 429 SCJ) to them they will explode too! LOL
Old Dec 30, 2014 | 12:09 AM
Montecz's Avatar
Montecz
Thanks for the links, I have had people say that I was nuts when I tell them I had one of those!
Old Dec 30, 2014 | 05:29 AM
Bud Mud's Avatar
Bud Mud
back in my day we called them an in-&-out box, they were either in 2wd or 4wd and that was it,no high no low and yes, seen 3 that i remember laying in pieces on the ground. Junk it and go with a NP205 and try to brake it.
Old Dec 30, 2014 | 08:10 AM
GaRedneck91
Ok I confirmed this mornin it's is a model 21. So I guess I need to get my hands on a 205. What all is needed for a swap. Was the 21 uncommon in these trucks?
