Help! Fuel pump Question
Old Dec 28, 2014 | 10:18 PM
omni's Avatar
omni
sorry don't want to use up your evening, How do I check the ground, Thanks
Old Dec 28, 2014 | 10:22 PM
JWC 3's Avatar
JWC 3
Easy . With your test lamp in series with the pump wiring . One end to the ground , one to the hot wire . Cycle the key . Test lamp should light . If you own and know how to use a DVOM , that would be better yet .
Old Dec 28, 2014 | 10:28 PM
omni's Avatar
omni
thanks. I'm assuming ground is black, could I screw something up if I hook it up wrong?
Old Dec 28, 2014 | 10:34 PM
JWC 3's Avatar
JWC 3
Not with a test lamp . It is just a light bulb . It does not care which end gets power or ground . It will light either way .
Old Dec 28, 2014 | 10:36 PM
omni's Avatar
omni
Its a four prong plug, could I hook power up to the wrong prong, say power to a non ground wire?
Old Dec 28, 2014 | 10:43 PM
JWC 3's Avatar
JWC 3
Then the lamp would not light . ... I ' THINK ' the plug has 2 sizes of wire . The 2 larger wires should be the pump , the smaller ones the sending unit .
Old Dec 28, 2014 | 10:47 PM
omni's Avatar
omni
Does the front and rear tank have the same ground source?
Old Dec 28, 2014 | 10:49 PM
JWC 3's Avatar
JWC 3
Not sure without a diagram . Let me see if I can log on to Identifix and find one ....
Old Dec 28, 2014 | 10:51 PM
omni's Avatar
omni
can't thank you enough for all your help. and putting up with my dumb questions
Old Dec 28, 2014 | 10:56 PM
JWC 3's Avatar
JWC 3
Can't log on from my home PC ... Sorry .
Old Dec 28, 2014 | 11:05 PM
JWC 3's Avatar
JWC 3
Not sure on yours , 1990 colors for front tank , R =power to pump . " O " I guess orange , is ground to pump . Front and rear tank get the ground from same spot . That is for a 90 mdl though ....
Old Dec 28, 2014 | 11:06 PM
omni's Avatar
omni
Thanks for trying. I'll try the ground tomorrow and let you know how it goes. I sure miss my old 77 f150, For a lame back yard mechanic like me,I knew my way around that truck. This 94 is an electrical challenge for me. If I change the pump should I get a complete unit or just replace the module?
Old Dec 28, 2014 | 11:16 PM
  #28
JWC 3's Avatar
JWC 3
If sending unit is good , pump avalible by itself , just the pump and sock should be cheaper . Best of luck . Let us know what you find .
Old Dec 28, 2014 | 11:19 PM
  #29
omni's Avatar
omni
thank again
Old Dec 28, 2014 | 11:25 PM
  #30
JWC 3's Avatar
JWC 3
No problem . Hope you get it sorted soon . Talk later ..
