I need another gear!
Old Dec 28, 2014 | 01:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
RUG SR-OD single rail 4 speed overdrive: 1978/83: misc 200/250/255/302 cars, F100/150 300/302 2WD & E100/150 300/302/351W
Cars & F100/150's: The shift lever fits into a flange located between the transmission and extension housing. The end of the lever fits into a nylon bushing that is notorious for cracking apart.
POS bushing is obsolete, available NOS and from Northwest Transmissions.
IMO, forget about the RUG, it's a "weak sister." Swap rear end gears instead, much cheaper plus the driveshaft won't have to be modified.
Old Dec 28, 2014 | 02:37 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by willowbilly3
In about 78-79 Ford used a version of the old cast iron toploader that had 4th gear overdrive. They were used in light duty pickups and vans, maybe a few cars (not sure). While not as stout as the old toploaders they will perform just fine for normal driving. I regularly see them for $100-$150. If you get one with the shifter, the hole in the floor and modifying the driveshaft should be about all the mods required. Pretty sure it's a bolt up.
Yup.. early to mid-80s. It'll bolt up neatly to a six. My neighbor had one behind his six with over 300,000 miles with no rebuild on the engine or trans. He is meticulous with maintenance. Those transmissions have a big RPM drop off between 2nd and 3rd gear and some guys don't like it for that reason.
He sold off his 81 F100 and treated himself to a Chevy Silverado. Five months later a drunk floozey forgot to turn at the dog leg and took out his Silverado. He was thankful because he had grown to hate it.... went out and got an F150.
Old Dec 28, 2014 | 07:14 PM
Rasputin53's Avatar
Rasputin53
Toploader 'imposters' (OD version) are not stout. Just sayin'. They were primarily used in passenger cars like the Granada/Monarch as a cheap OD option. It's the step between gears that actually gets you on these trannies. That torque change can be disastrous under significant load.
Old Dec 28, 2014 | 09:57 PM
orich's Avatar
orich
Adding an over drive trans or add on tail shaft over drive unit is for the most part not cheap.
Unless you just happen to get lucky and find a setup at the junk yard. But many guys have an eye out for one an hit the J-Yards a few times a week on the hunt for such tranny's or a gear vendor plus other o/d units.
So, I'd say your best bang for your buck is cheapest is changing rear end gears or to taller rear tires.
Putting in a car tranny's would not get you very low stump pulling gear if you were to use your truck like a truck. And sometime sound great until you spend $1800-$3500 for that extra gear then later find your getting 1.5 or 2 mpg more at best.
Your best gas saving speeds is like 50-55 the way it came rolling off the assembly line.
Also learning to operate your truck with a tach & a vacuum meter will yield your best gas mileage as, I found having driven my truck over 30+yrs using these two types of meters especially when towing or hauling..
Orich
Old Dec 28, 2014 | 10:27 PM
351Cleveland C4's Avatar
351Cleveland C4
X2 everything orich just said.
Old Dec 29, 2014 | 09:19 PM
Texasknowhow's Avatar
Texasknowhow
Thanks for all the replies guys. I have a lot to ponder, but I'm warming up to the taller gear in the third member. I wanted to go to a taller tire as well so I may just be able to do this swap and be happy with my original 3-speed. I think it may be a Top loader - has an access panel right on the top of the gear box...
Old Dec 29, 2014 | 09:20 PM
Texasknowhow
Orich
Thanks for summing it all up Orich!
Old Dec 30, 2014 | 10:15 PM
71Future5er's Avatar
71Future5er
Another gear option
Originally Posted by Texasknowhow
Hello guys, I am currently rebuilding the original 352 for my '67 F100 LWB and I'm in the hunt for a highway solution in the transmission department…
When this is back together I plan for it to be a daily driver and one of the coolest commuters that will be seen in the parking lot at work. Amongst all the Prius, foreign jobs and Yuppie vehicles, this thing is going to be so cool.
But guys, I need another top gear in a bad way. I've thought of a couple of solutions and wanted to run them by the forum and get the collective knowledge that only a forum like this can bring to bear on a situation like this.
Option 1: find an original overdrive transmission for the truck - it is currently a manual 3 speed on the column. This would need all the various control pieces, relay, vacuum line and port somewhere on the manifold, override pull lever/cable, etc. I would also have to shorten the front portion of the driveshaft between this trans and the middle joint (two part driveshaft in the long beds). This option would keep the truck sort of original in that you could order this truck with this option when bought back in '67.
Option 2: move to a floor based shifter and drop a 4 speed or even a modern 5 speed in there. - This option would require the column to be cleaned up replacing the shifter collar with a smooth (no shift lever hole) one, maybe slight mods to the tunnel area of the floor to clear the shifter and tranny?, and the obvious purchase of the said new transmission, and resize of the driveshaft.
I like this option as the trans would probably yield the best highway gearing with a true overdrive and I'm in control of all shifting, but this definitely goes away from keeping this truck original.
Option 3: You guys already know this one…. go to the Auto Trans like a C6 or even more modern with an OD. I don't really want this option personally because I kinda like shifting gears, but I could do this and have done this to a '63 I once owned.
Chime in, let me know if you guys have pros cons that I haven't thought of here and if anyone knows where I can find the trans for option 1, I'm in the market…
Clay
There is no direct bolt up OD option for you except in 1977-78 ford made a toploader overdrive. It is basicly a 4sp, but 4th gear is an od. It will bolt to your existing bell housing, but needs a 4 speed floor shifter. Check out Top loader imposters & David Kee toploader transmissions
Old Dec 30, 2014 | 10:27 PM
HIO Silver's Avatar
HIO Silver
A Tremec TKO is a bolt-on if spec'ed with a shortened 10-spline input shaft.
Old Dec 30, 2014 | 10:31 PM
71Future5er
Thanks for the info!
Old Dec 30, 2014 | 10:36 PM
HIO Silver's Avatar
HIO Silver
Stock bell housing and no adapter plate. Glory.
Old Dec 30, 2014 | 10:51 PM
71Future5er
Thanks again. I looked up the specs. Nice tranny!
Old Dec 31, 2014 | 02:11 AM
  #28
ultraranger's Avatar
ultraranger
The choice is yours and the only other factor that dictates outside of that is your budget but, a simple rear end gear change means you have to be willing to give up something. --either on the low end or the high end.
If you go to a lower gear ratio (higher numerically), you'll have plenty of low end grunt but, the trade off is getting even less gas mileage and higher engine RPMs at highway speeds. An engine that's being spun faster, to maintain a given speed, is naturally going to wear out faster as well.
On the other side of that, simply swapping to higher (lower numerically) rear end gears will give better fuel mileage and lower highway RPMs but, it means you have to be willing to lose low end grunt and pulling ability, --if you ever plan to pull a loaded trailer.
An overdrive is likely to cost more than simply swapping out the 3rd member in the rear end however, an overdrive will allow you to keep a low set of rear end gears for low end grunt and pulling a trailer but, the rest of the time, you aren't being penalized on the highway with high engine RPMs. --you get the best of both worlds, with an overdrive, that a simple rear end gear change, alone, can't provide.
In many cases, a lower set of rear end gears (with an overdrive) can actually end up being even higher than a high set of rear end gears, without an overdrive.
I'll give you an example. Let's say you had 3.25 gears in the rear end. This isn't a low gear set but, let's say you feel that's too low and you want to go to an even higher gear set so, you swap to a set of 3.00:1 rear end gears.
Your mileage and cruising RPMs may be better but, acceleration is going to be reduced as will your trucks pulling ability.
Now let's say you had an overdrive transmission and a set of 3.70 rear gears. 3.70 is lower than 3.25 and much lower than 3.00:1.
Let's say the overdrive transmission has an overdrive ratio of .68:1. Final drive equivalent with an overdrive is figured by multiplying the transmissions overdrive ratio by the rear end ratio.
.68 x 3.70 = 2.52:1
In overdrive, with 3.70 rear end gears, the final drive equivalent would be as if you had 2.52:1 rear end gears, instead of actually having a 3.70 ratio.
In the end, with an overdrive, 2.52:1 is much higher than 3.00:1 and as I think you can see by the math, you wouldn't give up low end grunt, acceleration or the ability to pull loads. The other side is you'll burn less fuel at highway speeds and have an engine that's turning less RPMs than you would with just a change in rear end gears.
Opinions are as varied as the number of people who will respond to this thread and can be argued over 'til the cows come home. However, math is based on absolute facts, not opinions. I think you can see, in the end, what direction will gain you the most here.
Old Dec 31, 2014 | 06:59 PM
  #29
smokenchoken's Avatar
smokenchoken
but don't forget to factor in COST X TIME / MECHANICAL ABILITY but other than that ultraranger is spot on with how i see it
Old Dec 31, 2014 | 07:39 PM
  #30
ultraranger
I had mentioned in my previous post that the budget would dictate the transmission that could be installed and that it would likely be more costly (on the front end) than a simple 3rd member/gear swap.
If the current transmission works, it can continue to be used while another transmission (overdrive), and all the related install parts are gathered. Once all the needed components are gathered, the transmissions can be swapped.
This would spread the cost out over time and not destroy the budget by trying to do it all at once. --it's the same thing I'm doing with my Ford 4R70W 4-spd automatic overdrive transmission.
I have most of the rebuild parts/tools to rebuild it. In the mean time, my stock C-4 gets the truck around until I can rebuild the 4R70W transmission that will replace the non-overdriven C-4. --by the way, I've never rebuilt an automatic transmission before.
A truck with no overdrive has to be geared to do one thing or the other; either it will be geared to pull heavy loads and will get poor mileage in the process or, it'll be geared to cruise at highway speeds, get decent mileage but will be greatly lacking in the ability to pull loads.
An overdrive transmission is the common denominator that will allow the truck to handle BOTH scenarios very well.
