which injector???
Old Jul 19, 2003 | 10:27 PM
NiteMan69's Avatar
NiteMan69
which injector???
I am putting a 302 HO cam in my bronco and am wondering if i should use the bronco oem injectors or the 302 HO injectors. I am still using the stock bronco lower and upper intake.
1991 Bronco 302 Nite Edition
Thanks...
Old Jul 20, 2003 | 10:45 AM
Brian460's Avatar
Brian460
which injector???
I would say you could keep you stock injectors. Keep in mind that with the HO cam you will need to use the 351W firing order, which all you have to do is redo the spark plug wires.
Old Jul 20, 2003 | 09:15 PM
NiteMan69's Avatar
NiteMan69
which injector???
thanks, i did rewire the distributor for the new firing order. Wll se how she comes out tomorrow. ..
