Bronco II Ford Bronco II
Trans adjustment
Old Jul 19, 2003 | 10:18 PM
IamToyoftherm's Avatar
IamToyoftherm
Trans adjustment
I was under the dash of my Bronco II again....and there is a ecm looking module that says automatic transmission solenoid and has a couple of adjustment screws on it. One for sensitivity and one for centering. My A4LD likes to kick down outta overdrive on the freeway, especially over slight grade inclines. Anyone have any idea what this adjustment box is, how to properly adjust it, and should it cure my problem? Thanks in advance!
Old Jul 20, 2003 | 04:12 AM
knucklehead11's Avatar
knucklehead11
Trans adjustment
Whoa, didn't know there was an auto tranny adjuster... cool!
Old Jul 26, 2003 | 02:21 PM
Scooter29's Avatar
Scooter29
Trans adjustment
I don't know the year of you II, but you may want to consider that most vehicles tend to do this. I beleive they are thinking too much for us. But if you do decide to adjust anything, just use a sharpie to mark where the original position was and your new mark. Use the sensitivity adjustment first. The centering is used when you have it in 4wd. Good luck and get back to us....
