Something Very Wrong
Old Dec 20, 2014 | 12:49 PM
PA74F250's Avatar
PA74F250
That's also weird you guys don't have ethanol of all things. I woulda thought it would have been the other way around.
Old Dec 20, 2014 | 12:54 PM
turbohunter's Avatar
turbohunter
LOL
Yeah, go figure.
Old Dec 20, 2014 | 11:21 PM
61steven's Avatar
61steven
I will have to try running the fuel injection line and a glass filter. Should I remove the carb to clean whatever might have caused blockage?
I still don't see where heat comes into the equation though.
Old Dec 20, 2014 | 11:41 PM
paredneck33's Avatar
paredneck33
I am tending to agree with earthquake. However I will also add that it could be the pickup coil on the distributor. When they start going bad the vehicle acts exactly as you describe. Sometimes you can get away with replacing just the pick up coil. But on a rarer occasion especially if you wait too long to replace it, you'll need a whole new distributor. Usually with fuel related issues heat doesn't matter. Maybe coincidental, but doesn't matter.
Old Dec 20, 2014 | 11:55 PM
61steven's Avatar
61steven
Okay so im not familiar with the inner workings of the distributor. What is this pickup coil? Would a stock unit work fine, or should I look for something performance oriented?
Old Dec 21, 2014 | 05:22 AM
gatorfor88's Avatar
gatorfor88
If you have duraspark ignition, a stock stator aka pick-up coil will work. Try to find 1 not make in korea,china etc. Very easy to replace. Pull distributor cap, disconnect plug in harness, pull rotor , pull reluctor ring , remove vacuum advance arm from stator,careful not to lose itsy bitsy c-clip, remove 2 screws holding stator on, reverse process to install new 1. Can do it in about 10 minutes. If you have some use di-electric grease when you put harness back together.
Old Dec 22, 2014 | 07:18 AM
somethingclever's Avatar
somethingclever
sounds like a spark issue to me...
Klemhineycutt
Oct 22, 2018 08:23 PM
djfins
Jun 15, 2017 10:33 AM
mechanic58
Jul 2, 2014 07:55 PM
Joel Mason
May 2, 2013 02:10 PM
Czarinca
13
Aug 20, 2007 07:14 PM
