Swap automatic to manual
Old Jul 19, 2003 | 03:48 PM
sequentialb's Avatar
sequentialb
I have a 1989 F350 crew cab with a 460 engine 7.5L and 3 speed automatic transmission. I would like to know if it is possible to convert it to a 5 speed manual. Any other useful info is appreciated including the pros and cons and whatever other info I need to know.
Ps. If anyone can please provide as much details as possible.
Old Jul 20, 2003 | 09:54 PM
elliott's Avatar
elliott
Yes, the auto to manual should be a bolt up once you find all the parts. (Hanging pedals, clutch linkage, bellhousing,flywheel, transmission). You may have to cut a hole in the floor for the manual tranny shift lever, and you may have to modify driveshafts. Hope this helps.
Old Jul 20, 2003 | 10:00 PM
steve83's Avatar
steve83
Contact "havack" thru his website: BroncoData. I helped him swap the E4OD out and an M5OD into his '93 Bronco last year and he can tell you part numbers & prices of everything you'll need.
Old Jul 22, 2003 | 10:52 AM
sequentialb
Hi Steve,
Thanks for the info. I contacted "havac" Sunday night and I'm waiting for his reply.
