Front fuel guage problems
Old Apr 3, 2002 | 09:31 AM
markus's Avatar
markus
Old Apr 4, 2002 | 08:05 PM
garyda's Avatar
garyda
I got a 1989 F150 with dual tanks. I don't use the front tank a whole lot but I went to flip the switch to the front tank and the guage goes a long way past the full mark. I was going to change tanks cause I am getting a slight miss sometimes and thought this might help. I think the tank is plastic so I didn't ever worry about the tank rusting. I was wondering if this is the sending unit in the tank???????????
Old Apr 4, 2002 | 08:40 PM
MustangGT221's Avatar
MustangGT221
Yes, it is the sending unit that will cause that fuel gauge problem.
Primary rig is:
95' F-150 EB 300/6 5 spd with 4" Superlift, MSD, Ram Air, Gibson Exhaust, 32" BFG Muds
NEW PICS IN MY GALLERY!! :-)
Then theres:
88' F-250 Superduty 351 + c6
92' Thunderbird 3.8L V-6 FOR SALE!
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 and a
3 spd column shifter baby.
The newest addition to the Ford family is a 99' Mustang GT 4.6L
Old Apr 4, 2002 | 10:11 PM
madman666's Avatar
madman666
Does your truck run on the front tank?
Old Apr 5, 2002 | 11:35 AM
rusty9's Avatar
rusty9
>tank???????????
yes it is the sending unit most likely. very common problem. i have the same problem with my rear tank and have done much searching on this subject. the general consensus is that a new sending unit must be purchased (not cheap) and that the easiest way to change it is to thake the box off rather than try to drop the tank.
Rusty,
Old Apr 5, 2002 | 08:29 PM
greymule's Avatar
greymule
Post Front fuel guage problems
garyda,
Does your gauge drop proportionately to the distance you drive? If so then the gauge is OK. The gauge in the front tank typically reads way past the full indicator in comparison with the rear tank gauge. The last time I install new gauges, I did both tanks (pumps/sender unit) june-2000 .... $425
GREYMULE
