86 F250
Old Dec 21, 2014 | 08:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Check that the red/blue 'S' wire does not have power except in 'start'.
Try giving that relay a solid rap with a screwdriver handle.
The contacts should jar loose and the starter stop cranking.
Old Dec 21, 2014 | 08:51 PM
Ranger1980's Avatar
Ranger1980
Give the solenoid a good smack with a screwdriver handle then try he battery again.
Old Dec 21, 2014 | 09:12 PM
Gary Lewis's Avatar
Gary Lewis
Junk yards are a good place to get them. Look for a Motorcraft one.
Old Dec 21, 2014 | 09:43 PM
ctubutis's Avatar
ctubutis
Yes, that small red/blue-stripe having power to it is what engages the relay... if that small wire has power all the time (should have power only in START) then the relay is doing its job.
IOW pull off that small red/blue wire... is the relay still stuck on and the starter spinning? If so, then do as the others have said and beat on it until it stops.
Old Jan 19, 2015 | 07:01 PM
mine747's Avatar
mine747
Well I went to the Ford dealership and got a brand new Motorcraft solenoid. Popped that baby in and the truck roared to life. Its almost roadworthy. Thanks everyone for your help. You dont know what it means to me that you helped.
Wicked Endings
28
Aug 17, 2022 05:29 PM
roosplash
Electrical Systems/Wiring
27
Apr 19, 2020 07:44 AM
Uncle Paul
May 22, 2014 09:33 AM
JoeSwing78
27
Jul 11, 2009 12:28 AM
Agemenon
37
Dec 15, 2006 09:13 PM
