Steering ? & and jerking problem
As I come to a complete stop (normal conditions) I can feel a jerk in the Bronco somewhere. Then when I start to roll, there is another jerk, kinda like there is some slack somewhere where there shouldn't be. The brakes and bearings are good, u-joints seem OK. I can't tell if it's in the front or rear, or in-between.
Also, I'm getting some play in the steering. Like maybe a couple inches of travel in the steering wheel before the wheels turn.
Could these two be related??? Any Ideas???
Thanks in advance.
Jim
also try the checking the ujoints and c-v head no load or out of verihcle
well jeff's bronco graveyard(R.I.P.) doesn't seem to have the rebuild kits for your rig(only to 86 but cv(head, collar seal ball & spring, also seal set) and u-joints are available
given the cheap/light duty materials that went into newer broncos it could be everything or anything
but the bushings are a suspect spot and there are so many more in a indipentant susp so this will cost you
then there are bad rotors or loose rear brakes
or it could just be a tranny thiing automatic obviously
have fun
Thanks again
Jim
I recently had what sounds like the same problem. What you call a "jerk" when stopping and starting I was feeling a "thud". I thought it was U-Joints or rear-end.
Took it to the local Ford dealership and it turned out to be the Slip Yoke Joint.........alls they did was "grease" it and it is now fine!!! Cost about $70 at dealership.
HAWK
95 XLT
front shaft let loose no warning sounds thuds etc
but not that it helps much here but the most common on old ones is a thud coming from the control(large beam from frame froward to axle) bushings when u stop or begin(less more in 4wd) it pounfs your cont arm into the mount or less often c-bushings
hey but new ones must have s-thing simular
but did u check the u-joints yourself by getting under n chacking 4 movement. be cause needs to be checked "no load" or in the air
the cv gives u a good pain and when it lets go it goes big more often than not dragging the back of the drive shaft is bad and expensive but imagine if u would the front(of the rear driveshaft) digging in like a big lever in the ground weeeeeee!
btw any clicking sounf going on turn the radio down and if city folk may have to do it at night found 3 am pretty good while i was in the city
