360 in my 72 250 gas mileage question
So I had a 70 f100 with a 390 and 4 barrel carb that got around 10 mpg. I've heard people say that the 360 was a gas hog but I couldn't imagine it to be worse than the 390. I have the stock 360 and 2 barrel now. I have replaced most of the fuel lines in it and I know I don't have a leak but I'm only getting 5 mpg. Is this about normal or do I have a problem somewhere?
I didn't think you could use the words "360" and "MPG" in the same sentence.
A 360 does get worse MPG than a 352 / 390. (I believe it has to do with the stroke.)
Aside from that, 5 MPG is a little too low. Your MPG could be affected by your engine not performing well, as ultraranger said. A tune-up may be able to help that. If you can't find a leak anywhere, it could possibly be your driving habits. What kind of driving are you doing, city / highway? What kind of transmission are you running? I do believe you should be getting around 10 MPG average. (At least that's about what I am getting in my 67' 4x4 with a 360.)
I have heard of 4 barrel performance 390s getting better gas mileage than mileage built 360s. I also was told that 360s make up for it in there reliability because they are not powerful enough to hurt themselves. (Not sure how true this information is, just coming from what I have read from other forum members.)
Sir, A Ford F250 4wd 4.11 gear ratio can not get 15 mpg even when being hauled on a trailer. If that feat were possible someone somewhere would be all over it trying to duplicate it and make a sheet load of money.
I don't meant to call you out, or try to make you look bad, but I have been around these ol Fords for a long time. I have owned them, driven them, hung out with others that owned them on this forum. Some info was added in wrong.
There would be 25 different venders selling this kit or that kit trying to make it happen again. You could be a wealthy man should you figure it out.
John
John
John
John
I haven't owned nearly as many as you. I am basing on F100 2wd 3.25 rear getting 12-13 tops, and you are claiming the heavier F250 4wd with a much lower ratio 4.11 getting 15. It doesn't add up sir.
You would be wise in sharing your secret, because a sheet load of money can be headed your way when others can achieve that kind of mpgs.
I do not want to make a bitter argument of this, so standing down.
best
John
best
John
best
John
best
John
I'm sure there are plenty of people who would disagree but I don't think the diff gear ratio makes as much difference as some people think. It takes the same amount of horsepower to propel a vehicle whether it's at 2200 or 2800 rpms. I've seen no measurable difference in the fuel economy of these trucks with 4.10s and 3.73s. But then I never tried both ratios in the same truck either.
F250's use Dana 60's, 1967/79 2WD available ratios: 3.54 - 3.73 - 4.10 - 4.56 - 4.88.
So don't assume that it has 4.10's, because it could be better or it could be worse.
If driving 60 MPH or faster, MPG drops off by at least 40% vs driving at 55 MPH
When "Tricky Dick" was in his 2nd term as prez, he mandated the double nickel (55 MPH) in an effort to improve MPG
This occurred during the 1st Arab Oil Embargo (1973/74). Another occurred in 1979 when Jimmy Carter was prez.
