Transmission
Old Jul 19, 2003 | 12:01 AM
justfarrell's Avatar
justfarrell
Transmission
I have a 94 f150 with 150,000 miles, 351w and a aod transmission. I had a fan go thru the radiator which has been replaced along with fan, water pump, thermostat, hoses, and idler pulley. It ran fine until trans started to shift hard. Fluid is a little dark. It has a code 628 in it. I can reset the comp but it comes back (hard shift). Is this a trans change? Do I go to Ford or is there after markets availible? Any info would be helpful.
