Would love to do a 4X4 Conversion on my Motorhome. Any Advice?
#31
It is hard to get a clear picture of the adapter. The transmissions are not the same from 97-08. I know the internal parts have changed but I think the housing may be the same on the trannys. I read on a forum that my computer will not be able to control the tranny if I swap them. If you know different please let me know. The 08 donor vehicle tranny has only 10K on it vs my 97 which has 130K. Thanks for your time
#32
Received 3,135 Likes
on
that is what i mean, i dont understand why they "are different"
i really think everyone is telling you they are different because one is a 4 wheel drive case, and the other is a 2 wheel drive case.
a 2 wheel drive does not have anywhere to bolt a t-case to. a 4 wheel case has a flange on the tailshaft to bolt the t-case to.
i really can't see where there could be that much of a difference in the gearing inside the case.
even if it is just a computer issue, i do not see why one of the transmission specialty shops could not get you a computer to make the new trans work on the old engine.
they make stand alone computers to do all kinds of things in trucks that never had a computer, or to work on carburated engines without any computer controls.
#34
#36
Yes, looking back you did mention that pathfinder made an adapter. This adapter is a Quigley made part. I just don't know if it will bolt up to my tranny. I don't know if the 2wd output shafts and bolt locations are the same between trannys. the 97 has the E40D and the 08 has the 5R110W
#37
#38
#41
on
#42
Let's assume I'm wrong and the bolt patterns are the same. The trans will bolt right up. All you'll need to do is invent a computer that can control it. I don't know of ANY existing aftermarket computers that can control the 5R110 that is in the 2008 chassis.
Here is an article that I wrote that explains why this is so hard: https://www.ford-trucks.com/articles...s-a-huge-task/
#43
on
#45
on
PCS makes a controller for the 5R110, a friend of mine did a 12V cummins swap in an 03 F250 not too long ago.
https://www.powertraincontrolsolutio...ow&per_page=32
