Hub Grinding question
Old Dec 20, 2014 | 01:00 PM
M-S-G's Avatar
M-S-G
Originally Posted by AllaboutMPG
M-S-G, The web page provided is for disassembling and lubing the factory "locking hub". You mentioned removing 6 allen screws earlier in this thread. Do you have after market hubs?
Indeed.
I stand corrected. Warn and Mile marker have allens.
I can't imagine many folks are left on the stock set of ford hubs.
Old Dec 20, 2014 | 01:10 PM
AllaboutMPG's Avatar
AllaboutMPG
I think the OP is still using factory because he said in the "auto" position.
To BigNick98,
I think I remember reading that the hubs require vacumn to both lock and unlock in auto. Before you tear everything apart check and make sure you don't have a vacumn hose off or leaking.
Old Dec 20, 2014 | 06:29 PM
M-S-G's Avatar
M-S-G
I think the OP is still using factory because he said in the "auto" position. To BigNick98, I think I remember reading that the hubs require vacumn to both lock and unlock in auto. Before you tear everything apart check and make sure you don't have a vacumn hose off or leaking.
You are correct Sir. Looks like my advice is on par with my reading comprehension!
ANigrelli132
Jun 24, 2014 10:38 AM
CAT_man_963
Dec 30, 2006 04:47 PM
Jpritchard
Sep 21, 2004 10:12 PM
