Door post fix for this?
Old 12-11-2014, 11:51 AM
jonf's Avatar
jonf
jonf is offline
This is a picture of the right hand center
Mounting bolt in the floor of my F-1 right next
to the door post. What do I need to do
to fix the cracks?
Old 12-11-2014, 12:06 PM
52 Merc's Avatar
52 Merc
52 Merc is online now
Received 2,518 Likes on 1,435 Posts
That's your center cab mount, and an area that is typically found like that on many trucks. Northern Classic Trucks has patch panels for this to rebuild that area, as I'm sure many other venders do, as well. These are their pics so it's only fair I give them credit and first dibs at the business..
Old 12-11-2014, 12:15 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
Here's the close up. I got it and other patch panels from Chuck at Chuck's Trucks in CT. Stu
Chucks Trucks LLC., Chuck's Trucks, Chucks Trucks
Old 12-11-2014, 01:01 PM
jonf's Avatar
jonf
jonf is offline
Do the patch panels for this go under the toe board and become the front mounting hole to the frame?
Old 12-11-2014, 01:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
They go over the floor panels. So you need to weld up or replace them first, after removing the old reinforcing piece shown above. The front cab mount is at the base of the firewall, under the battery tray. These are the center cab mounts. If your other mounts are in poor shape, it puts stress on this one = cracks. This one is the most "solid" connection to the frame.
Old 12-11-2014, 02:47 PM
Gicknordon's Avatar
Gicknordon
Gicknordon is offline
i just cut a small piece and welded it in when i fixed mine.
Old 12-11-2014, 03:54 PM
jonf's Avatar
jonf
jonf is offline
Many thanks to you all for the responses and recommendations. I have ordered the repair panels from Mac's. I went there to look for special clips for the windshield wiper linkage and was surprised to find them too.
Many of your pictures show the same kinds of cracking, so I'm wondering if it is also normal to see a crack where floor meets the toe boards. Mine is cracked most of the way across on both side, so I'll assume this was also caused by the cracks on the center bolts. The top rails of the frame under the bottom of the cab both have wear marks where the cab was hitting because of the bad rear mounting arms.
Anyway, I don't see reproduction toe boards and I wonder if it is OK to reinforce the floor to toe board connection by welding a bent strip of 14 gauge steel to cover the cracks. What say you all?
Old 12-11-2014, 04:52 PM
jonf's Avatar
jonf
jonf is offline
bump for the night crew and the west coast.
Old 12-11-2014, 05:16 PM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Jon,
If you don't find the patch panels you want at LMC, etc.
We used a member on here who goes by "reamer" - he makes
patch panels, etc. for the '48-'52 trucks. He also made a few special pieces for around the door sill & hinge where were just totally rotted out. I think he's a fireman in Connecticut & does this on the side as a business.
Good luck over there.
Ben in Austin
1950 F1
Old 12-16-2014, 02:40 PM
petemcl's Avatar
petemcl
petemcl is offline
Still Learnin'
I'm not sure what year your truck is (suggest that you add that info to your signature) but here are some pictures of my '50 F2 before I put in the new floorpan. Note that there is another structural piece that goes under the toeboard. Ross is correct, the piece that Stu showed you from Chuck's Trucks goes over top of the floorpan and should be welded into the side panel structure along with the floorpan.
440 sixpack
05-25-2019 06:59 AM
nzirbel
02-06-2015 08:50 PM
lavatan
01-14-2012 06:04 AM
reed1951
Ford Truck Parts for Sale
06-25-2011 07:53 PM
reed1951
04-24-2011 10:52 PM
Quick Reply: Door post fix for this?
