Temp Control On MAX A/C?
Old Jul 18, 2003 | 10:58 PM
soldierinthewind's Avatar
soldierinthewind
My question is when I have the A/C on Max, the Temp Control is not working.
I can turn the Temp **** all the way to Red and the temp stays the same, cold. I guess this is better than no A/C.
In the Normal A/C position I have temp control, but then have fumes from other vehicles and any other foul odor entering the cab.
The dealer’s service department says this is normal and there is nothing wrong with my truck, it took them two days of messing with it to tell me this, even though one of the service advisors checked another Ranger and he said the temp control worked as I would think it should. My understanding is the cold air is redirected over the heater core blending air to control temp.
Is this really “normal” for this year Ranger?
Any help would be greatly appreciated!
Old Jul 19, 2003 | 01:22 AM
Chris_ce's Avatar
Chris_ce
What year ranger?
Old Jul 19, 2003 | 07:04 PM
soldierinthewind
Oops, it's a 2000, sorry about that.
Old Jul 20, 2003 | 12:06 AM
Chris_ce's Avatar
Chris_ce
doesn't sound normal to me.You could always go to a car lot and try another ranger to see if it's the same.Will check mine tomorrow.
Old Jul 20, 2003 | 08:05 AM
Bob Ayers's Avatar
Bob Ayers
That's how mine works on a 1999. On MAX AC, the temp control
doesn't add heat, only on the AC position.
Old Jul 20, 2003 | 12:30 PM
soldierinthewind
Do you know if that is how Ford/Mazda intended it to work?
Old Jul 24, 2003 | 02:00 PM
treb's Avatar
treb
with my 99 reg cab 2.5 on max a/c circulates inside air only temp control works i turn it slow to less cool and can also hear comp kick out/in when needs to
Old Jul 24, 2003 | 02:04 PM
soldierinthewind
Thank you both for your replies.
Regards
Dan
Old Jul 24, 2003 | 04:07 PM
chadwj's Avatar
chadwj
I have a 99' Ranger and temp control doesn't do anything in Max position either. My understanding was that it was normal so I never questioned it. I'd be interested in knowing what the outcome of your search is.
Old Jul 25, 2003 | 11:01 AM
bcjim's Avatar
bcjim
As I understand it, the system is designed such that the temp control will not work in max AC because no hot coolant is flowing to the heater core and the outside air inlet door is fully closed. Thus, the position of the blend door is irrelevant ( a good thing for those of us with broken blend doors..) and the only air going through the coling system is the already cooled inside air which continues to get colder and colder...
JIm
98 SC 4x4 XLT
91K miles
