3.8 liter
Old Dec 10, 2014 | 11:07 PM
69issofine's Avatar
69issofine
3.8 liter
is the parts off of a fwd 3.8 the same or are they different just trying to explore all my options.
Old Dec 17, 2014 | 08:44 PM
Kruse's Avatar
Kruse
While some parts may interchange, the blocks are clearly cast with the FWD or RWD lettering right on the blocks. There are also some exterior parts, such as the water pump and water pump pulley, that are different.
I know because I have a '95 Mustang with the 3.8 and a '97 Thunderbird with the 3.8 and I've tried to replace lots of discontinued RWD parts with FWD parts and they don't mix. My advice is to keep looking for RWD parts to put in your RWD vehicle.
Old Dec 19, 2014 | 01:09 AM
69issofine's Avatar
69issofine
3.8 liter
i have a 95 windstar with a 3.8 liter engine and was wondering if a camshaft out of a rwd engine will fit ? my engine has roller lifters and there is a little rust on the cam lobes with a bit of pitting. where would be a good place to buy a new or reground one. would i need new lifters and pushrods,and rocker arms to? i am trying to go low budget. would used ones from the wrecking yard work or is that to redneck.
Old Dec 19, 2014 | 08:25 PM
Kruse's Avatar
Kruse
Well, I picked a year out of random (95), and it shows that the RWD and the FWD Ford cars use the same camshaft. I would have no problem reusing the roller lifters either, but would probably run them on the exact same cylinder that they were pulled out of.
MikeyLikesIt
Oregon Chapter
Apr 28, 2009 07:26 PM
low54
Mar 2, 2006 12:58 PM
maa139
General Automotive Discussion
Feb 14, 2005 04:18 PM
fordbeast_80
Apr 14, 2004 11:59 AM
badmechanic
Oct 21, 2002 10:55 PM
