Jolly Green Giant...2015 F-350 KR DRW
#9886
Received 6,719 Likes
on
In looking at properties I see a lot of garages with maybe 12' doors but not many with 14' doors. I look at the shorter ones with an eye to if it would be possible to increase the height of the door at all. Obviously, if the door frame is bordered by a roof line it isn't going to happen. But if there's a few feet of clearance above the door frame it should be doable?
#9887
#9889
Received 4,005 Likes
on
#9890
on
Worked on the garage this evening.......
Oops.... forgot pictures......
The last thing I did before breaking........ Mounted an outdoor electrical box with dual GFIC outlets. The wiring to the box was done, just needed to wire the feed to the two outlets. Now that is done......
It was nice to do something and it didn't require lifting or much effort. So, I behaved myself......
#9891
Regular household TP bio-degrades too........ That isn't what the filter catches....... The crusty coating that forms on the surface is what has to be kept out of the drainage field. It shouldn't get out in a proper tank. My tank settled outlet low..... so it is possible, that is what the filter is for in my case.
Glad you got to work on the garage again. I got the yard mowed last Sunday, and the pasture Monday. It's still a disgusting wet/muddy mess, but the weeds and taller grass were driving me nuts. I feel much better now.
#9892
Received 3,568 Likes
on
Roy, Glad you got it and worked on the garage!
I got out and worked a little around here also. Just haven't got motivated to work on the Bronco again. I did look at it yesterday and decided I need to move the shock brackets on the rear axle.
#9893
on
Howdy Doug and Tim........
It was really nice to do just something on my garage project...... Maybe another little bit today.
All of us are going for a walk with the doggies today...... My 1st walk since I broke.......
#9894
Roy, fire #3 reared its ugly head today, but thankfully not at my facility. It's a few miles east of us and I sent 11 of my guys and some equipment to assist.
#9895
on
Sure is going to be tough to put out..... sad.
#9896
on
We all got in about 1/2 mile walk today....... My first since being broken. Went well. More tomorrow.
#9897
We are members of an organization called CIMA - Channel Industries Mutual Aid. We are broken into zones and if anyone in your zone has an emergency too big to handle on their own, everyone else responds with equipment, supplies and manpower until no longer needed. We have had them out here before, and we have assisted others on multiple occasions. This will be a long process for sure.
#9898
on
Do local Fire departments help with these fires ??
#9899
Although several of the municipal fire departments are also members of the CIMA groups, they don't generally help a bunch, as they aren't typically equipped to handle these sorts of issues, unless they are airport apparatus. Most municipals carry water on board, but no foam, and typically have lower capacity pumps than what we use in industrial firefighting. They are always willing and ready to help when they can though. Likewise, CIMA occasionally gets called to assist the municipals for things like large tire fires. The airport trucks are pretty bad-azz though!
#9900
on
