Jolly Green Giant...2015 F-350 KR DRW
#8642
Received 4,005 Likes
on
The brake line that came in the kit is steel........
#8643
on
#8644
on
Much accomplished today.......
Disc brake actuator and brake hose.....
Rats nest of hyd hoses and wires a wee bit neater
Brake hose from the Actuator connected to the brake line ........ ready to be secured to the bracket.
Brake hose connected to the caliper
Brake line running inside the frame
Disc brake actuator...... Brake hose...... bracket...
Brake line inside of frame......
Brake line inside the frame
Brake line connecting to the brake hose .... hose connected to the Actuator....
Disc Brake Actuator ...... brake flex hose....to bracket that holds the end on the brake hose where the brake line connects to the hose.
Brake line running inside the frame....
Hyd hoses and wires bundled and the Brake Line running inside the frame...
Bracket on frame..... brake hose and ridge brake line meet here.
Brake line on the inside of the frame.
Brake hose from caliper to bracket mounted on the frame.
Hyd hoses and wires bundled and fastened up out of the way.
Brake line in the background
Axle in position to bolt up to the springs....
2nd axle in place..... ready for the disc brake assy.
Torque wrench used... good boy !!
Hardware to bolt the axle to the leaf spring
Tube bending and cutting tools
#8645
on
BTW:...... I found a crossmember that servers as a floor joist and controls frame flexing with a broken weld....... It is welded to the left and to the right frame..... It is no longer welded to the right (Starboard) frame.
What terrible workmanship...........
#8646
Received 5,160 Likes
on
Well done so far Roy, Your paint job reminds me of my late Fathers painting, he was color blind too, really
#8647
on
But my color choices might be a wee bit "different"......
I am having fun with it.......
Thanks Gerry....
#8648
on
#8649
on
Photos from Saturday.........
Brake line work....... Had to make an adjustment on the mounting of the Rubber brake hose from the caliper to the ridge brake line.......
Custom piece of brake line.......
Wheel Nut and retainer
Loading grease in the wheel bearings
Grease Seal.....
Seating the grease seal
Attached a wheel/tire to insure there is good clearance with the brake hose......
Caliper bracket attached...... First torqued with Torque Stick.......Then with Torque Wrench
Final torque.....
Caliper pins and bushings have "caliper" grease applied......
Keeping all the brake line above the underbelly covering (enclosure)
Grease Seal.....
Final torque.....
#8651
on
Thanks Dave...... Getting closer to being done.
I won't have much time this week to work on the Montana and finish...... I have been asked to sub for a High School teacher at Foothills Community Christian School (FCCS). He will be gone all week. Bible, History, Geometry, Trig........ I am rusty with the math, but it'll work out fine......
#8655
Good luck with the math. I considered myself pretty good in the math department in school, but man did it change with the grand kids math books. This new math sucks.
