Jolly Green Giant...2015 F-350 KR DRW
#8626
Received 4,005 Likes
on
Brake over..... Back to work.....
No injuries .......Yet
#8627
Maybe the forum thought the keyword "Tuffskins" was relevant due to Roy's busted knuckles on this project?
#8628
on
Speaking of........
I was wearing cloth gloves.... Drilling out a rivet on a small piece of metal...... Using the drill press...... While drilling into the rivet the drill bit reached out and grabbed my left hand glove.... Pulled my finger into the side of the drill and bit it big time before I hit the off switch...... More chewed-up tissue and blood loss........
#8630
on
Al least there was some progress made today..........
Finished all the primer coat.....
Almost finished rearranging all the wires and hyd hoses......
Decided to junk the brackets that hold the generator exhaust pipe in place....... Very rusty and the rubber piece to isolating vibration was almost ripped through. I'll make my own.
Planned out the brake line route...... Got the big coil straight...... I tried pushing the brake line through a small diameter plastic water pipe about 6 ft long....Worked well, the brake line is pretty straight.
Painted the big diameter tubes that hold the sewer hose.......
Sewer hose tubes
Cleaned up area
Rusty area before cleaning
Under belly braces primed
New Toys
Straighten brake line
Sewer hose storage tubes......
Finish coat on braces........
Sewer hose tubes
Cleaned up area
New Toys
#8631
on
Should have put the small piece of metal in a vise......
#8632
Received 6,718 Likes
on
Roy, I'm interested to see what you do with the generator exhaust pipe. Mine makes a clunk sound at startup and shutdown. At operating RPM it's fine. I need to take a closer look at it to see what the problem is.
#8633
on
I'll post when I built them (2) and install them.
#8634
#8635
Tuffskin doesn't apply to me..... I cut easy....and bleed a bunch.
Speaking of........
Speaking of........
Take care of yourself, Roy.
Bruce...
#8637
So, Roy, your comments about running brake line through small diameter water pipe. Was that just to straighten? Or are you thinking of leaving in permanently? I ask, because my dad did that years ago on his boat trailer on certain sections, thinking he was making things more reliable. The problem, and I realize a boat trailer is different with being submerged in water(always fresh water, we dont live by any oceans) a lot, but what happened is that the brake lines that were inside the tubing rusted out because water that managed to find it way inside the tubing, never dried out and the exposed brake lines were fine. So, I guess food for thought.
#8638
on
#8639
on
I am finally going to run the brake lines today and mount the 2nd axle.....
Should have some nice pictures tonight.
#8640
on
I'll do better Boss !!!
