Jolly Green Giant...2015 F-350 KR DRW
#8566
Received 3,998 Likes
on
Roy,
With you having the entire bottom exposed, any need or thought to running additional propane lines like others have done here? Provide well located and protected quick disconnect for Rodney type fire pits or LP grills? Are there any rubber LP lines that are exposed and should be checked for cracking?
bruce...
bruce...
I am swapping out all fasteners for SS hardware.....
#8567
on
Did get some more rust control work done. Also installed one disk brake assembly....... Then spent a bunch of time with the State Farm claims adjuster and a roofing contractor.... Hail damage to the roof.
#8569
on
Nawwww.... Not for me. Coffee is my drug of choice.....
#8572
on
No shocks.....
There are the Rubber Springs between the two axles that damping road shock.....
I don't feel there is a need for conventional shocks...
#8573
on
I am looking forward to getting this done.......
I have been having too many interruptions lately.......
#8577
on
Dealing with roof re-shingling.....
Stuff at Church.....
Broken Body.....
Broken Body.....
#8578
on
Some work done today.......
Caliper bracket bolted to axle....
Ready for the caliper.........
Caliper pins lubed..... Threads have anti seize compound on them....
2nd Axle springs painted.......
Caliper bolted on...... All done.
#8579
on
Report on the battery powered grease gun.......
This thing is Great !!!! Good control over grease flow rate.......
I am Happy
I am Happy
#8580
Coming along nicely Roy!
I just bought a cheap 3oz manual grease gun for doing trailer axle bearing grease, and already had a large general purpose grease gun for my tractor, but I may have to buy one of those battery operated ones after hearing your review.
