Jolly Green Giant...2015 F-350 KR DRW
#8296
Received 4,043 Likes
on
Running new wire from the pin box into the forward compartment. Larger gauge for power from the truck. Brake controller in truck to the new disk brake actuator.
I fished a length of conduit from the pin box to the forward compartment.
#8298
Looks good, Roy...nice work! That heavy gauge wire sure is expensive.
Maybe I missed it...how are you planning on getting more power from the truck to the trailer? Aren't you limited by the max draw through the hitch?
#8299
on
The long run of undersized wire is creating too much voltage drop....... So I will increase the wire size for the entire run.... from truck batteries to the Montana batteries. The 7-pin connector can handle enough current I believe.
#8300
on
Now to get the sonar and radar systems running....................
#8301
Just passing along a link that I found interesting.
Linky1
I've also read that you should consider increasing the size of the grounding wire at the 7 pin connector on both sides to handle a possible increased flow back to the truck.
Bruce...
#8302
on
Roy:
Linky1
Bruce...
Linky1
Bruce...
Yes, I have also increased the ground wire size......!!
#8303
on
Wiring and Disk Brake work
Finished some wire upgrades and got the Disk Brake Actuator installed.......
#8304
on
#8305
Received 6,832 Likes
on
#8306
on
Still waiting on the 8K axles to arrive..... But, I have plenty to keep me busy.
The rotors take 2 men and a boy to carry...... The hardware is heavy stuff.
#8307
on
Do the new axles come with leaf springs and if so will they bolt up to the existing mounting points?
#8308
on
The new springs are 4K lbs each.
The old ones are 3.5K each.
One of the old ones lost the arch, and is flatten........
#8309
Looking good Sailor !
Wish I could be there to give you a hand.
The wifey is making me drywall the garage,while she is home for spring break.
She is good help so I don't mind.
#8310
Tim, it's nice that your wife will help with drywall. I'm certain Jodi would help as well, but then we would have two people who at drywall, doing drywall.
Looking forward to more progress pics Roy. Just try not to overdo anything with your back!
