Jolly Green Giant...2015 F-350 KR DRW
#781
Only suggestion I'd make is cutting off the excess bolts and either grinding the top smooth with top of nut or removing the nut and installing acorn nuts. I just reread you were going to do this already...never mind. Sorry.
Did you relocate it there so it's easier to plug in?
#783
He has the swing in storage boxes that mount to the rear of the bed, and the wiring and plug would be in the way when the box is swung in.
#786
Received 4,005 Likes
on
I am using the nylon insert nuts so they wont vibrate loose. Acorn nut with lock washer would be great too. Nylon insert nuts.....in stock.
#788
on
For me, I have a swing out tool box that needs that space to be installed......
#789
on
Can't get a thing past Sam......
#791
on
Boy......That IS True......
#792
on
Gerry.....Andre.....AJ.....Sam
Thank you all for the comments...suggestions...and kind words...
I have also decided that I need to seal the area where the 7-pin socket meets the plastic cover of the tailgate. No need allowing water to access the inside of the tailgate.
Some refinements or modifications are in the works..........
#793
#794
How the heck did I miss the planned swing out tool boxes? I'm down right nosey and borderline stalking this truck???
Thanks for the explanation
