95 -01 Transmission Swap Question - Please Help!!!
Is it possible to use a 1995 Ranger manual trans from a ext cab 6 cyl 4x4 and use it in a 2001 Ranger 2+2dr extended cab 4.0L SOHC to replace a shot auto trans?
- 2001 trans (55R55E) is shot and needs to be replaced
- have junk 1995 ranger with good 5spd (Mazda M50D-R1) manual trans in it
HELP!!
HELP!!
Last edited by andycollen; 12-08-2014 at 09:51 PM. Reason: made a mistake in model year of one of the trucks
You said the 1995 manual trans is a V6. Which V6? There was the 3.0 V6 and the 4.0 OHV V6 offered that year. The 3.0 has a different pattern and will not work. The 4.0 OHV has the same pattern as the SOHC and will work. I think there is an extra bolt on the SOHC that the OHV didn't have (or vice versa), but it's not a big deal as long as the rest of the bolts are tight.
