fuel gauge woes
Old Jul 18, 2003 | 08:21 PM
MMCGRA's Avatar
MMCGRA
Unhappy fuel gauge woes
I have a 1997 ranger. The fuel gauge reads empty ( goes to 1/4 with key off). I checked that the gauge was good, then went ahead and replaced the pump/sender assy. I put key on, still reads empty. I took sender out again, plugged in harness with the sender out of the tank, the gauge reads where I put the float like it should. I put it back in the tank and re-connect, it reads empty! Help! It seems like the tank is grounded or something.
I can't see anything wrong with it. Any help appreciated. Thanks
Old Jul 18, 2003 | 08:23 PM
GR8Diesel's Avatar
GR8Diesel
fuel gauge woes
Just a passing thought; How is the ground to the tank?
Old Jul 18, 2003 | 08:41 PM
MMCGRA's Avatar
MMCGRA
fuel gauge woes
Hi. Where is the ground to the tank, in the harness?
Old Jul 18, 2003 | 08:48 PM
GR8Diesel's Avatar
GR8Diesel
fuel gauge woes
I am not familiar with your vehicle, but I have seen some strange things happen when a ground has been lost due to corrosion.
Hopefully, someone with 1st hand knowledge of your vehicle can help.
Old Aug 7, 2003 | 09:26 AM
69newagain's Avatar
69newagain
fuel gauge woes
Hey MMCGRA, Did you find the problem??
I have the same thing and was about to replace the unit.
Dave
Old Aug 7, 2003 | 09:31 AM
69newagain's Avatar
69newagain
fuel gauge woes
Dave
Old Aug 7, 2003 | 10:32 AM
gdoggy's Avatar
gdoggy
fuel gauge woes
Same here........MMCGRA are you out there somewhere.....???
Old Aug 7, 2003 | 11:36 AM
gondothegreat's Avatar
gondothegreat
fuel gauge woes
Yeah, I've had the same problem with my 94 since I bought. just figured it was the sending unit. I'm gonna check my ground this weeken. I just couldn't see either dropping the tank or lifting the bed to change the pump just for the luxury of a guage. i guess i'm lazy.
Old Aug 7, 2003 | 11:45 AM
69newagain's Avatar
69newagain
fuel gauge woes
So how far do you dare go before filling up?
I felt 300 miles would be safe??
Old Aug 7, 2003 | 11:50 AM
gondothegreat
fuel gauge woes
well, I moslty travel Highway miles - about 180m/d - Just on the safe side, I fill her up between 220 and 250. Usually I don'tput more than 11 gallons in it.
I'm sure I'm not getting the gas mileage I should be, but I don't have the money to make sure EVERYTHING is in 100% working order.
Old Aug 7, 2003 | 11:57 AM
69newagain's Avatar
69newagain
fuel gauge woes
I thought I had a long drive at 100 miles a day!
I bought this 97 for a good price with the guage not working and a leaking oilpan thinking "I can fix that, no problem"...........that was before I found out engine pull for the oil leak and tank pull for the sender!!!
