Brake fluid flush
Old Dec 7, 2014 | 01:08 PM
RV_Tech's Avatar
RV_Tech
Brake fluid flush
I posted this earlier on the brake forum, but so far no responses (I guess cuz it is Sunday and things are slow).
I suspect the brake fluid in my 02 is original and I thought it might be wise to change it (62,000 actual miles), but in going through the owners manual and recommended service intervals, I can find no mention of brake fluid flushes.
The brakes are fine, but since I tow with the truck I like to err on the safe side. Any thoughts about this?
Also, since I have an abs system, do I have to do anything differently?
Thanks,
Steve
Old Dec 7, 2014 | 05:29 PM
takotruckin's Avatar
takotruckin
Brake fluid should be changed every 2-3 years, as it absorbs moisture over time. Nothing different with the ABS. Just suck the reservoir dry (vacula or turkey baster), fill it with new fluid and then bleed the brakes. Our trucks use about a quart, maybe a touch more to make sure all the fluid is new.
Old Dec 7, 2014 | 06:04 PM
Stewart_H's Avatar
Stewart_H
Steve, go to the Excursion forum and click on the tech folder sticky thread (I really need to finish upgrading the one here in the 7.3L forum) and scroll down to the section covering brakes and brake bleeding.
You'll find a very good thread there on how to bleed the brakes, and when ABS affects how you bleed the brakes.
Stewart
Old Dec 7, 2014 | 06:06 PM
Franko72's Avatar
Franko72
Molon Labe
I bled all four corners a while back and the fluid was black.
Glad I did it. IIRC I used at least one large bottle of brake fluid.
Old Dec 7, 2014 | 06:12 PM
RV_Tech's Avatar
RV_Tech
Thanks all for the responses. I was surprised not to find anything in the scheduled maintenance.
Steve
Old Dec 7, 2014 | 06:20 PM
RV_Tech's Avatar
RV_Tech
Stewart
Good how-to, I bookmarked it.
Thanks,
Steve
Old Dec 7, 2014 | 08:01 PM
MSP-F250's Avatar
MSP-F250
Stewart
Damn! I've got so many things saved for the future, I need an index!!
Thanks for the link. This isn't me yet, but probably not long ...
Old Dec 7, 2014 | 08:45 PM
F350-6's Avatar
F350-6
Steve
They assume it will get done when the brakes are done. They don't assume only having 62,000 miles in 12 years. But that's common across all makes and models.
Old Dec 8, 2014 | 09:11 AM
BadDogKuzz's Avatar
BadDogKuzz
OOppsss Double post.
Old Dec 8, 2014 | 09:14 AM
BadDogKuzz's Avatar
BadDogKuzz
Steve you might already know this but I would inspect the brake line that runs from front to rear along the frame rail for rust. Mine wasn't leaking yet but there was enough rust back by the fuel tank that I replaced the line. Also I used Valvoline Syn Dot 3 & 4 to help combat the moisture issue of Dot3.
Valvoline.com > Products > Brake Fluids > DOT 4 Brake Fluid > Valvoline® DOT 3 & 4 Brake Fluid
Old Dec 8, 2014 | 10:18 AM
cj45lc's Avatar
cj45lc
Good tip on that brake line...mine rusted out a couple of years ago
Old Dec 8, 2014 | 11:35 AM
RV_Tech's Avatar
RV_Tech
Thanks for the heads-up.
Steve
Old Dec 8, 2014 | 12:53 PM
hydro man 17's Avatar
hydro man 17
Valvoline.com > Products > Brake Fluids > DOT 4 Brake Fluid > Valvoline® DOT 3 & 4 Brake Fluid[/QUOTE]
A while back I was considering going to DOT 4 fluid in my 4Runner and was told that it is not compatible with the cups and seals designed for DOT 3 fluid. Is this really so??
Old Dec 8, 2014 | 05:37 PM
CGMKCM's Avatar
CGMKCM
I would flush the PS system and hydra boost also. Between flushing both systems my brake pedal feel improved quite a bit.
Old Dec 8, 2014 | 08:02 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Dot 4 does nothing for moisture issues in all the research I have done, it only increaes the boiling point which is better for hard use and 4 wheel disc vehicles.
Mixedup
Aug 26, 2016 05:35 PM
jmtbiggin
Large Truck
Oct 26, 2014 10:21 PM
Rusty Bumper
2004 - 2008 F150
Apr 4, 2012 03:10 PM
Deiselman
Apr 4, 2007 06:42 PM
BiodieselPanther
1983 - 2012 Ranger & B-Series
Jan 13, 2006 09:12 PM
