Sponsored by: Real Truck
Shuddering
Old Dec 6, 2014 | 10:50 PM
crazymut's Avatar
crazymut
Shuddering
Lately when making a turn from a stop, more so after having driven for some time on high way, my truck will shudder. The best way I can describe it is, it feels like being in four wheel drive turning on pavement except maybe not quite as bad.
Old Dec 6, 2014 | 11:25 PM
pYr8's Avatar
pYr8
Kinda sounds like ALS symptoms but best to see the doc J/K
Seriously though, what do your front tires tell?
Old Dec 6, 2014 | 11:33 PM
crazymut's Avatar
crazymut
As far alignment and balance everything is fine. When this happens I'm only going about two miles an hour. Usually it would be when I'd give a little throttle to get going, tonight is was with just letting off the brake and letting it start rolling on its own edging into parking spot as someone was pulling out
Old Dec 6, 2014 | 11:49 PM
pYr8's Avatar
pYr8
Still kinda sounds like a tire thing. Kinda like their rolling under on the turn. Pressure OK?
If were under power it would sound like the rear end is locked up & both rears are pushing you.
Is there anything loose in the steering or suspension that you've noticed?
Old Dec 7, 2014 | 12:07 AM
crazymut's Avatar
crazymut
Nothing loose that I've noticed. I'll check the air pressure. Didn't think of that. Don't drive the truck much at all anymore except for elk hunting trip from California to Idaho and back. Out to the duck blind and occasional camping trips. And getting Christmas tree tonight. I did have 4x4 issue on elk trip, still don't know what the problem was. Would not go into 4 lo.
Old Dec 7, 2014 | 12:18 AM
pYr8's Avatar
pYr8
As a guess, it may be 4x issues, but from what I hear, I'm kinda at a lose.
K
Old Dec 7, 2014 | 12:26 AM
crazymut's Avatar
crazymut
You and me both. Thanks for the help though.
Old Dec 7, 2014 | 12:57 AM
crazymut's Avatar
crazymut
Been doing a lot of searching on this forum and sounds like it could be the rear end. That's given my rear end is a 3.73 limited slip with a clutch pack. I know very little about rear ends. I know it is due (way due) for fluid change in rear end and from the sounds of things that can be the root of the problems. I'll check into it and let you know.
Old Dec 7, 2014 | 07:48 AM
projectSHO89's Avatar
projectSHO89
Probably the LS clutch packs chattering.
It helps tremendously if you provide the specifics of the vehicle that you're asking about.
Old Dec 7, 2014 | 11:33 AM
crazymut's Avatar
crazymut
2001 F250 7.3 4x4 short bed xcab
Old Dec 7, 2014 | 02:37 PM
iamrfixit's Avatar
iamrfixit
My 2000 with 4:30's and limited slip would shudder real bad as I backed out and turned first thing in the morning. I would notice it at other times too, but it was especially bad after sitting overnight. I changed the fluid in the rear differential and took it for a drive in a big parking lot turning several tight figure eights. It was better but not completely fixed. It seemed to get continuously better though and soon the shudder was completely gone. Mine was also well overdue to be changed.
Old Dec 7, 2014 | 06:56 PM
crazymut's Avatar
crazymut
Just changed my diff oil and went for 12 mile test run. So far so good. I'll drive it to work tomorrow and see for sure.
Old Dec 7, 2014 | 07:53 PM
EXv10's Avatar
EXv10
If not , add a little friction modifier at a time...........not too much. Add and test, give it a week between.
Old Dec 7, 2014 | 08:00 PM
crazymut's Avatar
crazymut
I changed as per guzzles instruction page, friction modifier already in.
Old Dec 7, 2014 | 09:57 PM
droldsmorland's Avatar
droldsmorland
How many miles on your rig? Check the front U Joints. If they are binding due to being dry on grease they will do what you describe. But so will LS clutches.
If you did the rear dif fluid and added the LS additive do a series of figure 8s in an open area to allow the fluid to really work into the clutch plates.
