Egr voltage
Old Dec 5, 2014 | 04:08 PM
Brotherbillstruck's Avatar
Brotherbillstruck
Egr voltage
Quick question. Looking at expected readings for scanguage yesterday. I noticed EGV should be 0.8 at koeo. Well i show 0 volts. I then checked my EGD and EGM(valve position measured and desired) and i also showed 0 volts while at idle. Might be a dumb question but is my egr valve toast? Thanks
Old Dec 5, 2014 | 07:55 PM
04badford's Avatar
04badford
input these=
EVD=txd 07e02209d2 rxf 0462050906d2 rxf 3010 mth 00647fff0000
EVM=txd 07e02209fe rxf 04620509066fe rxf 3010 mth 00647fff0000
ETP =txd 07e022096c rxf 04620509066c rxf 3010 mth 00647fff0000
Old Dec 5, 2014 | 08:16 PM
Brotherbillstruck
Thanks 04badford. Will try those numbers tomorrow if i have time and report back. I do get some voltage numbers while driving on the EGV- it varies from 0 to 1 or 2. Even numbers no decimals
Old Dec 5, 2014 | 09:21 PM
04badford's Avatar
04badford
as you throttle higher the Valve position will go up, at Idle it should be around 75/80 some time's around 85 witch is borderline what you don't want is high at 15 and low stuck at 85% as far as the Volts I have never really watched that.
Old Dec 5, 2014 | 09:28 PM
04badford's Avatar
04badford
some EGR Values are just seeing V-ref like the one you posted so that's good . the one that make a diff are EGR Duty Cycle, valve position, the EGR vpd reads high at 9.75 take these tests in park, sitting just Idle and at 2500 rpm for high.
mtnxtreme800
Apr 10, 2012 10:32 PM
vancouver island
35
Oct 28, 2009 04:24 PM
Ryan50hrl
Jun 2, 2005 09:49 PM
PaulR
1983 - 2012 Ranger & B-Series
Oct 5, 2004 08:50 AM
