Hood Keeps Coming Down
Old Dec 6, 2014 | 01:35 PM
binuya's Avatar
binuya
Originally Posted by F250_
There are different part numbers for left and right, and the two are actually priced differently as well. Regardless, they are identical parts, so just get two of the cheaper part number.
Great insight right there! Reps sent.
Old Dec 6, 2014 | 04:37 PM
dn29626's Avatar
dn29626
Sachs Stabilus SG304029 - Lift Support | O'Reilly Auto Parts
Old Dec 6, 2014 | 04:39 PM
dn29626's Avatar
dn29626
O'Reilly Auto Parts
$19.99 Each
<table><tbody><tr><td> </td></tr></tbody></table>
Quantity Per Vehicle: 2
Sachs Stabilus - Lift Support
Part Number: SG304029
Line: SAC
  • limited lifetime warranty
  • UPC: 43645713980
  • Hood
  • Compressed Length (In): 11.496 Inch
  • Extended Length (In): 17.323 Inch
  • Lower Mount Type: Ball Socket
  • Travel Length (In): 5.827 Inch
  • Upper Mount Type: Ball Socket
Detailed Description
Manufactured to automotive O.E. performance and quality specifications. Restores the original opening and closing speeds of your hood, hatch or trunk. Easy to install. No special tools required. Exact replacement, engineered for your application. Rust-resistant piston rod extends product life. Easy lifting, reduced closing effort. Consistent lifting force through 50,000 cycles.
Additional Details
  • Color: Black
  • Compressed Length (mm): 291.998mm
  • Extended Length (mm): 440mm
  • Hardware Included: No
  • Pounds Of Force (Lbs): 97 Lbs.
  • Rod Diameter (In): 0.315 Inch
  • Tube Diameter (In): 0.709 Inch
  • Type: Gas
Old Dec 6, 2014 | 04:53 PM
Pikachu's Avatar
Pikachu
Rock auto has the Sachs brand at $10.35 each. They're under Body ---> Lift Support.
Old Dec 6, 2014 | 08:44 PM
F250_'s Avatar
F250_
I learned the hard way... AFTER purchasing both part numbers and confirming in my own hands that they are identical... it was not worth the cost of return shipping to swap out the more expensive one.
abe
May 15, 2017 04:38 PM
jwhitetail
Jun 20, 2007 09:05 PM
twr
Apr 14, 2001 07:50 PM
