where do I look to get info on slipping an explorer rear end in this 94 f150. And how much wider the f150 rear is than an explorer. I want to run an 18inch wheel with at least a 2inch polished lip and 10 inches wide. Also redrilling the front rotors and turning the hub down to allow 5on4.5 mustang wheels?
All I have figured out thus far is it is 44 inches from spring perch to perch and an explorer is 40.5 that wont matter it will get a 4 link and coilovers
Actually I think that I found my information it seems the explorer rear will be 3 inches per side shorter. So it looks like I will need to get the tape measure out and see if that will work. If I have to mini tub so be it.
thank you I have been hard at work figuring out a few measures on this thing. I think I am going to get the truck in and pull the blown up 5.0 out and prep the engine bay for the new setup. the inner fenders are going to be removed and battery moved to a truck box in the bed. this truck will be the wifes race car hauler. so I am going to have to lighten this pig up. any suggestions?
