First Powerstroke (96 F350 CCLB) *Large Pictures*
This truck was the original owner's baby, only the guy I bought it from treated it like crap. If the console isn't some sort of 90's aftermarket manufacturer equipment, which upon closer inspection seems less likely, I'm sure the original owner either made it or had it made.
I did some serious internet digging, and it looks like the running boards and rear bumper were made by a company called J&J Enterprises. J&J supplied a lot of equipment for Centurion, hence my friend recognizing the truck and thinking it was a Centurion setup. J&J also made special lighted grab handles, which explains the little grommets under the grab handle mounts on my truck. They might've been for the wiring. Sadly, J&J has long since gone under and the chance of finding exactly what the truck had on it again is slim. Here is a link to a site selling what I think originally was on the truck: Hummer J&J Hummer, H2 & H3 Grab Handles
Might end up removing the metal anchors from the exterior metal and patching it, then drilling some newer grab handles like:
I'm also trying to figure out the nicer set of wheels. The driver side's wheels seem to be aluminum and much better quality than the passenger side's steel wheels. I'd love to try and find a full set of the aluminum wheels to replace my mismatched, half-plastidipped current ones.
That or it was just used because it somewhat matches the interior. That or they just replaced all the hardware at some point. Fade like that would indicate the console is much older than the truck, or has seen a lot of sunlight. Even the stitching on the handle looks new!
The _holes_ are what's asking for rust. Since the holes are already there, there's no added risk of rust by doing something with them. If anything, there's probably less risk of rust with handles there, rather than the exposed holes.
But that's in the future. First priority is getting the bed dent fixed, fixing up the roof from the visor damage, and getting a matching set of wheels
Here's a new question for you guys. My truck's rear fuel tank won't take fuel, when I try to fuel it up the diesel foam instantly is up at the neck clicking the fuel nozzle off. After a few seconds it gurgles and the foam/fuel goes down into the tank. I'm assuming that a vent somewhere is clogged, but haven't had a moment to really look at it.
on
1 Post
haha, that's for sure! With my towing I have a 38 gallon rear tank and a 33 gallon aux bed tank so in total I can hold 90 gallons. I still at times get stuck filling up at a truck stop and the vent mods come in real handy there.
#30
