2005 Ranger Heater Problem
Old Dec 2, 2014 | 12:42 PM
dfox912's Avatar
dfox912
Got a 2005 V6 Ranger with low mileage. Having a heater problem. We've replaced the thermostat, heater core, flushed the system twice, burped it to get the air out and replaced the hot water valve. The heater works for a few days then it goes cool: not cold. Adjusting "Temp" will make the temp decrease but it will not return to hot air. ??????????
Old Dec 3, 2014 | 11:10 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
Could be a water valve? I know you replaced it, try bypassing it by plugging the vacuum lines and manually opening the valve to insure hot water gets to the heater core. Are the heater hoses hot on both sides of the valve?
Old Dec 4, 2014 | 08:49 AM
pawpaw's Avatar
pawpaw
Blend door problem maybe, it's a common problem part in heater woes & if you find its faulty, there is a rework procedure in the "Tech Info" thread atop this forums index page that you could try. Let us know what you find & how it goes.
got2befast
Oct 28, 2010 11:10 PM
Fedman
Oct 14, 2008 09:18 PM
flo21i99
Nov 5, 2006 02:06 PM
Frank Kistner Sr.
Aerostar
13
Feb 3, 2005 03:32 PM
Huggy Bear
Feb 6, 2002 10:41 PM
