Suspension mods
Old Dec 1, 2014 | 08:33 PM
Fordnatic68's Avatar
Fordnatic68
Suspension mods
Any modders or hot rodders out there do a crown vic front suspension swap into an 80-96 f100 0r 150? I know its been done to pre 80 trucks but I have a 94 shortbox 150 with a 351 fuel injected engine and lots to come. Any tips or pointers Im all ears, Thanks!
Old Dec 1, 2014 | 08:35 PM
'89F2urd's Avatar
'89F2urd
whats your end goal?
Old Dec 1, 2014 | 08:38 PM
Fordnatic68
Low and mean, not sure if ill keep the windsor or swap a big block in or??? I work in the diesel modding side but love my little gasser.
Old Dec 1, 2014 | 08:40 PM
'89F2urd's Avatar
'89F2urd
how low? 2wd ibeam suspension is hard to beat for a lot of reasons.
Old Dec 1, 2014 | 08:43 PM
Fordnatic68
I thought about a drop i beam swap n stumbled onto the crown vic swap. I think for handling reasons alone it looks like a good way to go. But I havent lowered a vehicle in 25 years lol.
Old Dec 1, 2014 | 08:48 PM
'89F2urd's Avatar
'89F2urd
the crown vic, or any small control arm setup, wouldn't be all that bad if you have a welder and a buncha time. I don't think any gains would justify the work required for that particular swap, but if its for a hobby project then any "is it worth it"'s go out the window.
Old Dec 1, 2014 | 08:55 PM
Fordnatic68
Its a bunch of work no doubt but im into it. My 03 in my profile pic is in the midst of a frame up resto, second make over for it.
Old Dec 2, 2014 | 08:34 PM
Chumpy's Avatar
Chumpy
the 351 with a 434 stroker kit in a Dart block with AFR 215's should make about 550hp on the motor then just hit it with a 225hp shot of spray(or more) and call it a day . Plenty of hp with out all the weight of the diesel on the nose of a short wb truck.
Old Dec 2, 2014 | 11:17 PM
f100beatertruck's Avatar
f100beatertruck
I'm not sure the frame rails are the same width. I know it works with the Dentsides and older trucks, but they changed a lot in 1980...
For those that don't know about the CV swap, here's a great thread on one.
https://www.ford-trucks.com/forums/1...sion-swap.html
The CV frame rails are 34" wide.
Vman72
Apr 25, 2017 08:11 AM
ehug21
May 18, 2014 09:58 PM
Jrf100
20
Jan 2, 2012 04:32 PM
Dyerstown
Nov 7, 2002 04:06 PM
