Confused !!!!!
Old Jul 21, 2003 | 09:18 PM
willowbilly3's Avatar
willowbilly3
Confused !!!!!
Since only the shaft itself is shorter, why is it such a hassle to just shorten it? I have converted 2 72s, one auto and one 4 speed. When I did the 4 speed in about i986 you could still order the shaft from Ford. When I did the automatic I had a donor steering column, but when I went to use the shaft I found out it was too short to fit in my existing column. I am not sure of the year but it was only a year or so off and from the same body style. I ended up using the whole thing which wasn't a problem since both were black. I also have a 68 and was considering just shortening the shaft so I can keep my blue column. If I remember right the new one I bought was listed for 1972 only.
So what is the big problem with cutting down the old shaft?
