Sponsored by: Real Truck
Ignition Click
Old Nov 29, 2014 | 08:42 PM
Garymc41's Avatar
Garymc41
Ignition Click
2000 F250 Crew 5.4 125000 miles.
Sometime when the ignition is turned only a click is heard. Several tries and several clicks then all of a sudden truck starts. After starting speedometer wont work then it will start working. Truck runs great. This problem does not happen all of the time but often enough to not trust the truck on long trips. Ignition switching block has been replaced. Any ideas would be helpful.
Old Nov 30, 2014 | 12:00 PM
seville009's Avatar
seville009
I had a similar problem with a 99 Expedition years ago. Problem was the battery cables. Check that they're clean and tight, or replace them.
Old Dec 2, 2014 | 04:35 PM
Garymc41's Avatar
Garymc41
All of the cables are good. The odd part is it don't happen all the time. When it does crank the starter turns the motor over good. I wonder if it is a relay because the speedometer wont function and haul light flashes.
Any help is appreciated.
Old Dec 4, 2014 | 08:14 AM
sunuvabug's Avatar
sunuvabug
My Camry had the same symptoms but it didn't happen all the time ... just once in a while. Over about 6 months, it did get a little worse until one day ... nothing. It would only click once when the key was turned and wouldn't start. It was a starter that finally died.
Old Dec 18, 2014 | 03:07 PM
duelly581's Avatar
duelly581
clicking no start
my 03 f350
I found a connection between the main battery cable corroded at a joint on top of the left plastic fender skirt ,under or behind the aux fuse box. cut the corroded parts out put new lugs ,bolted them together taped them real good and problem solved. mine was intermitent also.
LRSTony
1997 - 2003 F150
Jun 11, 2015 03:40 PM
CaperFord
38
Jan 29, 2012 04:53 PM
abitua5
Sep 29, 2009 08:54 PM
ToolDude
17
Apr 22, 2004 02:37 AM
con400
1997 - 2003 F150
Feb 2, 2003 10:04 PM
