'78 Crew 4x4 - Cummins Swap Begins - Build Thread
#256
The only fuel connection to the P pump is the fuel inlet and a fuel return. Both are banjo fittings. Using Teflon tape is a bad idea on those connections. Especially when a fuel leak in those places are easily fixed by new banjo washers.
#257
Sorry I bailed from the Swap Meet before getting that Grill Shell to you, I was wiped out after no sleep Saturday night.
This past week I've had a nightmare of a VERY steep learning curve concerning Diesels and Fuel Problems. Air Intrusion is a massive problem on my rig with the 6.9, one of the hardest areas to find was that the Hard-line had rubbed through against the frame and would seal enough to run fine until the road got bumpy causing the line to bounce away from the frame and suck air in. Issue's with Hard-lines aren't too common but it's something to look at. Another of the many problems I had was the Tank Transfer Switch/Valve was letting Air in the system, so I bypassed that non-functioning POS also, then I blew 3 Return lines that tie between the Injectors. After all that crap it ate the new lift pump, slapped an electric pump on it tonight and did a 60 mile round trip with Zero issues. After the move I'll be running all new Fuel Lines from tanks> manual Transfer Valve> Electric Pump> Injection Pump.
My point is... Do you have any way you can Pressure Test your lines?
#258
If you are losing your prime I bet it is up on the IP after the fuel shutoff solenoid. There is enough wiggle room in the IP and fuel filter to keep the system primed with fuel even if the fuel pump in the tank send little pockets of air. Those little air pockets just get sent back through the return lines.
When I first got my truck running it would lose prime over the course of a couple hours but never leaked fuel anywhere. I finally took off all the fuel lines on the IP and put some Teflon tape on them and out them back on. Never lost prime after that. One of them had just a tiny imperceptible air leak.
#259
He is running a P pump cummins so I am unsure what your are referring to there. the fuel shut off solinoid is purely mechanical and has nothing to do with the fuel flow from the lift pump or fuel filter itself. The fuel shut down on a p7100 pump mechanically turns the racks and blocks fuel flow shutting down the engine.
#260
I did remove the banjo bolts that are on the feed line into the filter from lift pump when I replaced the lift pump. Didn't put new washers on, so that could have an impact. I also loosened the banjo bolt on the overflow so I may need to check that again.
#261
Received 3,791 Likes
on
#262
#263
Yes they are all banjo bolt fittings but mine have an extra port in the head of the banjo bolts. I think they are 1/8" NPT plugs.
#264
That would make perfect sense then for the teflon tape. You had me lost on that one. Mine do not have the extra 1/8" ports. Would be a good place to plumb in a fuel pressure sender.
#265
Got the hood latch support made tonight, painted and installed.
Here's some "in process" pics without the grille
And here's the whole I burned in my flannel while using a cutting wheel to do some trimming
Was wondering what was so hot...looked down and there was a small flame coming up my shirt. Ooops.....
On to the trans controller wiring tomorrow.
#266
Grill inserts are installed. I must have put that first one in the shell 20 or more times. Second one went a little faster. Did the drivers side first
Then the passenger side.
Also did a little interior wiring for the trans. Got the manual switches hooked up for the overdrive and lockup. Sure makes a difference.
#267
#269
#270
I took it on about a 20 min freeway drive. Running in OD with the TC locked up with no throttle it'd run about 600 EGT. I don't have a speedo yet, but was running a little faster than traffic so probably 65 or 70. If I got on it it'd go up to 1,000 pretty quick and even up to 1,100. What's too high for too long?
