Just bought truck a week ago or so.. As some of you know. Trans lines to the cooler where not hooked up as it was leaking coolant into trans. I figured that out after purchase. Fluid on stick didn't look that bad put once I dropped the pan to do filters it looked like pepto bismo..
I did the normal filters and fluid change but I know there is still 10 quarts of junk fluid in there.
Dropping truck off in the am for a hot flush. Anything I should tell them? Like take the external filter out before flush. I plan on replacing that one anyways (again) once I get the truck back.
Any other recommendations?
Thank you all!
And yes.. New mishimoto radiator and trans lines are hooked back up
Hopefully it's a true heated flush....very few places actually have it. Many times people have ordered a heated flush and received a dump and fill instead. Or they get a regular flush that won't accomplish much, due to the internal thermostat not opening.
Hmmmmm I will ask. Will even reschedule if he will let me. I talked to him for about 15 mins. Today... younger kid. 25 I'd say.
He might let me record some.
Ok.. just did a ton of reading about the walker ford dealer here in clearwater. Bad bad bad reviews about their service department. So ill be going to the st.petersburg dealer.
I will do as stated on this thread.. ask a ton and try to record. Update coming soon.
