help please
Old Nov 25, 2014 | 02:58 AM
gretchen5150's Avatar
gretchen5150
help please
1978 f150 single cab short bed trans oil leak at the fitting for the radiator (which is brand new) could the fitting be bad?
Old Nov 25, 2014 | 03:39 AM
co425's Avatar
co425
Have you checked and made sure it's tight?
Old Nov 25, 2014 | 03:41 AM
gretchen5150
The fitting or the hose clamp over the fitting?
Old Nov 25, 2014 | 04:38 AM
co425's Avatar
co425
You said leak at the fitting. Check and make sure it's tight since your radiator was obviously recently replaced. May as well check that hose clamp as well too.
Old Nov 25, 2014 | 04:41 AM
gretchen5150
Ok ill check but i was saying i didnt know of the leak came from fitting or the little metal piece that goes around the hose to the fitting that tightens with a flat head. But ill check the fitting when the sun comes up its only 5:40 am right now
lifted77f250
May 31, 2011 12:51 PM
Fourwheelinj1
Apr 16, 2007 09:09 PM
Fourwheelinj1
Apr 11, 2007 09:15 PM
ArizonaDPS
3.0L V6
Jan 7, 2004 11:27 AM
