Not seeing any major failures in the 6.7......
Old 11-24-2014, 09:28 PM
Amelio's Avatar
Amelio
Amelio is offline
Have been watching this board since I bought my truck in 2012....... Back then I wanted the 6.7 but could not afford it or justify the cost for what I need.
Things are better for me financially and I am looking to make a deal this week. I am looking at a 2015 4x4 CC Platinum..... The pricing the dealer is offering is pretty insane and they are giving me a rough offer on my truck which will pay it off...... This has been done over the phone and swapping vin's and pics.
Anyway it sounds promising and I plan to visit the dealer this Friday to see if it happens.
Back to my point....... I have not really seen any major issues with these new engines..... I remember early on there were a handful of fuel system failures due to contamination but haven't seen another in some time.
I still see some radiator issues and I assume the '15s will have the same issue since it's the same radiator.
I also remember a while back about some engines dropping valves but that seems gone also.
So really it's just the typical EGT sensor failure and the radiator.
What else has been common with the later year 6.7's?
Old 11-24-2014, 09:50 PM
David1986's Avatar
David1986
David1986 is offline
I'm also looking at purchasing the same truck a 2015 F350 SRW. I have the same concerns with purchasing a new one.
Good luck on your deal!
Old 11-24-2014, 11:29 PM
Ltngdrvr's Avatar
Ltngdrvr
Ltngdrvr is online now
Received 3,359 Likes on 1,779 Posts
There have been a number of recurring sub system failures besides the radiator and EGT sensors.
DEF heater/level sender, trans front pump, and a few others.
My issue was that all of these failures occurred on my truck just slightly after the truck was a year old, but outside the mileage limit of the warranty and ford basically told me "tough luck".
Old 11-25-2014, 05:11 AM
senix's Avatar
senix
senix is online now
Received 1,428 Likes on 1,021 Posts
Early ones (2011) had some valve failures.
It also took them a couple of years to get the transmission figured out.
Radiators on anything 2008 and up now are prone to failure due to the cheap way they are built.
My 2013 has been very good so far. It has not been back to the dealer since I bought 14 months ago.
Old 11-25-2014, 06:27 AM
BlackBeest's Avatar
BlackBeest
BlackBeest is online now
If we're "piling on", I had an issue with a leaking brake vacuum pump, and found out I wasn't alone.
Also dealt with (and still have to address) the trans shift solenoids, my 2-3 needs replacing (I don't recall which one(s) they replaced last time....)
But again, I've got a job1 '11, we read/hear less and less issues with the '13+ trucks, tho to be fair, they are perhaps too new to get a good sample.
If that's the truck you want, go grab it
Old 11-25-2014, 08:41 AM
Amelio's Avatar
Amelio
Amelio is offline
I think they have probably worked out most of the bugs by '15 and I am not sure what changes they will make for '16 and I don't wanna be the beta tester for a new truck. I also don't want to wait until '17 to buy one. Plus the deal they are offering me is pretty crazy if they hold true to their word when I show up on Friday.
If they stick to their quoted price I will be driving it home Friday afternoon!
I know that there are and will always be problems but I am mostly glad that the large catastrophic failures are very few and far between right now.
Small problems are here and there and some guys never have any issue at all....if I happen to have something go wrong....well hopefully Ford takes care of it under warranty.....I am also looking into an extended warranty plan as well but I think I may hold of on buying it until the factory warranty is almost up.
Old 11-25-2014, 09:10 AM
Tom's Avatar
Tom
Tom is offline
There certainly have been a fair amount of engine failures, particularly on '11-12 model year trucks with failed valves. I wouldn't say it's a common issue, but we've had a few on this forum have engine replacements as a result. Haven't heard of any recently, so I think the valve issue has been resolved in later years.
Otherwise they seem to be very reliable engines. I had an early-build '11 for about a year, and other than a turbo replacement it was good to me. Most have had excellent service from theirs, and I wouldn't hesitate to buy another one.
Old 11-25-2014, 03:16 PM
MouseMendez's Avatar
MouseMendez
MouseMendez is offline
When I heard they beefed up the problematic EGT sensor/valve and switched to larger turbo I pulled my trigger. Good Luck.
Old 11-25-2014, 05:17 PM
sandyc's Avatar
sandyc
sandyc is offline
Your hearing lot of negative things here and yes, those folks with problems do indeed have engine issues, but here's the positive side of this motor. In 2011 job1 produced (est) 45,000 trucks. Job2 and upward till the 2012's produced
(est) 220,000 trucks=265,000 diesel 6.7 trucks for 2011. These numbers were given to me by a friend in an executive position with Ford. The problems that you hear of, on different forums are such a small percentage compared to actual sales and use. I myself have a job1 2011 with 50K miles and it's never had a motor issue, A/C issue once, but that's it. Would I buy another one, absolutely.
Old 11-25-2014, 05:35 PM
miner999r's Avatar
miner999r
miner999r is offline
i recently bought a used 2011, nice truck but the def heater and heated hose went south on me on the first road trip. out of warranty and i was reluctant to use my after market warranty on a relatively trivial issue.
Old 11-25-2014, 10:01 PM
StanleyZ's Avatar
StanleyZ
StanleyZ is offline
I've been on FTE for 13 years. From 2009 to 2013 I was on the 6.4L forum. Compared to that this 6.7L forum is putting me to sleep. Just going by what's on here these trucks are wonderful. They have no problems.
Old 11-25-2014, 10:13 PM
FishOnOne's Avatar
FishOnOne
FishOnOne is offline
Received 1,458 Likes on 902 Posts
And I came from the 6.0L forum
I have ~57k miles and not a single problem.
Old 11-25-2014, 10:46 PM
my_crib_too's Avatar
my_crib_too
my_crib_too is offline
Received 1,183 Likes on 364 Posts
These are good days to own a diesel pick-up truck.
Old 11-26-2014, 01:30 PM
Amelio's Avatar
Amelio
Amelio is offline
yeah the little to no problems with these new diesels is giving me the warm an fuzzies and I am looking forward to this Friday.....I hope the deal works out I am excited!!!
FordServiceCA's Avatar
FordServiceCA
FordServiceCA is offline
Official Ford Rep
Thumbs up
Originally Posted by miner999r
i recently bought a used 2011, nice truck but the def heater and heated hose went south on me on the first road trip...
Congratulations on your recent purchase, miner999r. I'll be happy to look into your concern. Please pass on the odometer reading; I’ll check the available resources. Also, I suggest taking the vehicle to your dealer for diagnosis.
Kwasi
Quick Reply: Not seeing any major failures in the 6.7......
