Electrical Problems
Old Nov 22, 2014 | 01:52 PM
Argonman's Avatar
Argonman
Electrical Problems
Hello,
I have a 2007 E250 that has no rear parking lamps or Licence Plate Lamp "on" when the headlight switch is turned on, however the front lights are on.
I have checked and tested fuse # 10 which is the fuse related to these items
Any help would be helpful
Thanks
Old Nov 23, 2014 | 06:38 AM
JWA's Avatar
JWA
You have a bad connection somewhere in the wiring harness feeding the rear of your van.
Get an EVTM or Electrica-Vacuum Troubleshooting Manual aka "wiring diagram" and start looking there.
There are no less than 8 connectors that could be at fault but most of what you're describing aren't fuse-related.
Old Nov 23, 2014 | 07:58 AM
Wildman25's Avatar
Wildman25
If, you have a trailer connector, check that first, most prone to problems where the OEM wiring is tied into the connector.
The rear lights connectors are also a problem spot. Where the tail lights branch off the main rear harness.
At worst, I have on several vans ran a new 16ga wire from under the dash, to the rear, bypassing the numerous connectors, thus providing a new circuit feed for the problem (park/turn) lights.
Also, a 12v test light is needed to find where the circuit "died" and for trouble shooting.
Sorry, I couldn't tell you what color wire you'll be looking for, not familiar with your year, maybe someone else will chime in on that?
koyoteturtle
Electrical Systems/Wiring
May 4, 2017 10:46 AM
86'F-150
Jan 14, 2013 10:48 PM
evojason
Nov 22, 2009 08:18 PM
emgee
Aug 19, 2009 01:40 PM
johnsjp
Oct 24, 2007 02:14 PM
