stranded help
Old Nov 19, 2014 | 10:21 AM
got2befast's Avatar
got2befast
stranded help
While driving lost boost, regained, lost boost a mile later, regained. Pulled into gas station no boost everything checks good on scan gauge except VGT is at 85%? Needle won't move off 0 boost. VGT solenoid?
Old Nov 19, 2014 | 11:08 AM
dannyboy950's Avatar
dannyboy950
Possibly just remember the VGT may be commanded at 84% for some reason. Also keep in mind the oil to the turbo and vgt is from the low pressure pump.
Compare your VGT desired against the actual.
Old Nov 19, 2014 | 11:09 AM
WatsonR's Avatar
WatsonR
or the unison ring is stuck not allowing the vanes to move
Old Nov 19, 2014 | 11:42 AM
got2befast's Avatar
got2befast
My IPR and ICP read normal so I would think my oil pressure is good. Turbo was rebuilt about 60,000 back by ford house never had any issues till now.
Old Nov 19, 2014 | 11:47 AM
John Irwin's Avatar
John Irwin
CAC tube off or a hose split?
Old Nov 19, 2014 | 11:50 AM
Captn B's Avatar
Captn B
Exhast Back Pressure sensor? Try unplugging it and see if it builds boost again.
Old Nov 19, 2014 | 11:54 AM
tim.moman's Avatar
tim.moman
Might check EBP. Stuck vanes/no boost EBP would be very low and build some with throttle. Die off hard when throttle cut.
Old Nov 19, 2014 | 12:10 PM
dannyboy950
High humidity can be majot factor I have had turbos freese back up in less than a month.
Just saying.
Old Nov 19, 2014 | 12:13 PM
got2befast's Avatar
got2befast
Will unplug ebp sensor. How long can I drive if that's the issue my truck is 7 miles from home.
Old Nov 19, 2014 | 12:15 PM
got2befast's Avatar
got2befast
And when it died off almost felt like engine shut off but all rpms and other gauges maintained.
got2befast's Avatar
got2befast
Checked cac all looked good.
Old Nov 19, 2014 | 01:29 PM
tim.moman's Avatar
tim.moman
If you think the turbo froze up I would pull the aircleaner tube and see if the turbo spins. As for 7 mile drive. It should make that with easy driving to get you home. The only failure would be if the turbo has mechanical failure that could run thru the engine.
Or are you saying it dies and won't run now?
Old Nov 19, 2014 | 01:34 PM
got2befast's Avatar
got2befast
It will run just absolutely no turbo what so ever.
Old Nov 19, 2014 | 01:42 PM
dannyboy950
I was more referring to the unison ring freezeing back up. If the turbins are froze he has way more problems than just vgt.
Old Nov 19, 2014 | 02:55 PM
got2befast's Avatar
got2befast
Checked MAP connections, hose and VGT. Unplugged EBP have turbo back. How long can I run without EBP?
