C-6 Question
Old Jul 17, 2003 | 05:52 PM
tripticker's Avatar
tripticker
Question C-6 Question
Does the C-6 tranny have an adjustable modulater and if so where is it located?
Thanks in advance to anyone who can respond.
Old Jul 17, 2003 | 05:55 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
Most after market vacuum modulators can be adjusted.
It has been 20+ years since I saw a C-6, isn't the modulator at the rear by the pan?
Old Jul 17, 2003 | 05:57 PM
tripticker's Avatar
tripticker
C-6 Question
GRiesel,
Not sure what the modulator is and what to look for......
Thanks......
Old Jul 17, 2003 | 06:03 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
Then why would you want to adjust it?
The vaccum modulator is a device that translates changes in manifold vacuum into changes in transmission oil pressure to modify shift points/characteristics.
When you look at your transmission you will generally see three tubes going into it. Two of them go into the side of the transmission case and connect it to the oil cooler in the radiator.
The third tube orginates in the engine compartment and carries vacuum from the intake manifold to a cylinderical (sp?) unti that screws into the transmission.
It it is adjustable, the adjustment screw will be inside the vacuum port of the modulator. Remove the tube to gain access, don't modify unless you want to really hose up the transmission.
When it is failing/out of adjustment the tranny will not shift up until the engine is really wound up, or the transmission will shift early cutting your performance.
Old Jul 17, 2003 | 07:26 PM
tripticker's Avatar
tripticker
C-6 Question
GRiesel,
Thanks for the help. I probably wasn't too clear as to what I needed. The problem I am having is the tranny is shifting early and I think is lugging the engine. I hope that is the term I am looking for. I barely get the truck rolling and it shifts the first time and before I reach 30MPH it shifts again regardless of the load I have on the truck.
Thanks so much for your help.
Old Jul 17, 2003 | 07:31 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
Change the modulator, fluid, and filter.
Then see where you are.
Shifting early is not as common as shifting late for a bad vacuum modulator.
Does that transmission do this even when floored?
The reason I ask is the downshift linkage overrides the vacuum modulator.
Old Jul 17, 2003 | 07:33 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
Old Jul 17, 2003 | 07:36 PM
tripticker's Avatar
tripticker
C-6 Question
Yes GRiesel it does it even when it is floored
Old Jul 17, 2003 | 07:40 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
I suspect you may have a sticking valve in the valve body.
When you change the oil in the transmission it is not a difficult task to remove the valve body to clean it up.
Before you do:
Get a chiltons or other manual on the C-6.
Have a clean, clean, clean and well lit place to work.
Work slowly, carefully and make sure you keep track of every ball bearing (used as check valves), spring and valve go. Errors are not tolerated. You may want to put in a Shift-Kit at this time.
Not only will it give you directionrs for removing and disassembling the valve body, you'll get a new modulator and better shifts.
Good luck, let us know how it works out.
Old Jul 17, 2003 | 07:44 PM
tripticker's Avatar
tripticker
C-6 Question
Thanks GR8Diesel. I appreciate your time to help me understand what is going on with my tranny.
I let you know how it goes.
Old Jul 20, 2003 | 10:19 PM
Usta's Avatar
Usta
C-6 Question
Pull the hose off the modulator and tee in a vacuum gauge. You could be experiencing trapped vaccuum. Should have @ 16" to 21" of vaccuum at idle. Jazz the throttle and should flash close to zero. If it stays at high vac. and or drops slowly, suspect trapped vac.
Old Jul 20, 2003 | 10:27 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
You could just remove and plug the line to the modulator and you should then see reluctant shifts where the trans winds the motor up a bit before each one.
Old Jul 21, 2003 | 06:23 PM
Usta's Avatar
Usta
C-6 Question
Yu could do that yes. And when you find out it shifts late and firm you'd have to tee in a vac gauge and find your problem.
Old Jul 21, 2003 | 07:03 PM
GR8Diesel's Avatar
GR8Diesel
C-6 Question
Usta,
I agree with you, I'm just suggesting a quick way to triage the tranny or not. If he gets late hard shifts, then we know we have an issue like what you have described. I certainly don't want to have tripticker go pullin the valve body out for what appears to be a sticking valve unless we can rule everything else out. Your suggestion is wonderful in that it reminded me of a necessary step, that of operating with zero vacuum. I don't know if he has a vacuum gauge or all the necessary plumbing required by your more definitive test, but I can be he can lay his hands on a screw to plug the line and do it quick and dirty.
Tripticker,
I expect a status report - you have two people here very interested in a successful outcome :-)
Old Jul 21, 2003 | 07:22 PM
Usta's Avatar
Usta
C-6 Question
actually, the first thing i would have done is yank the hose for a short roadtest. Probably even under the hood rather than getting on my back. But your right!
