'Wait To Start' light stopped coming on...
Old 11-12-2014, 01:12 PM
Larry Wall's Avatar
Larry Wall
Larry Wall is offline
This morning (cold morning) I went to start my 96 F250 7.3L and it turned over like normal with a little bit of white smoke coming out of the exhaust like normal too... I turned the key a couple more times to get it started and all the sudden the usual 'Wait to start' light on the dash doesn't come on anymore and I'm getting no smoke at all while it's turning over now...
Another funny thing I have a diagnostics tool from Edge Products so I figured plugging that in would diagnose the problem, but for some reason it was never even able to connect to the PCM! It just kept saying turn the key off, turn the key on over & and over again...
Anyone had any similar problems to this or does anyone have a solution perhaps?
Old 11-12-2014, 02:01 PM
Larry Wall's Avatar
Larry Wall
Nevermind fixed it myself...fuse #22 was blown
Old 11-12-2014, 02:07 PM
fordpride's Avatar
fordpride
fordpride is offline
Disconnect the fuel bowl heater are it'll blow again
Old 11-12-2014, 02:10 PM
madpogue's Avatar
madpogue
madpogue is offline
Good chance it'll blow again. There's a heating element in the fuel bowl which shorts out, and blows that fuse. In their infinite wisdom, Ford put the PCM and that heater on the same fuse. Heater was designed into the bowl in the early '90s, and winter fuel has improved (wrt anti-gelling, anyway) greatly since then. With good fuel, and an anti-gel additive for good measure, you don't need the heater. If the fuse blows again, disconnect the heater; connector is on the driver's side of the fuel bowl, single-wire flat blade terminal, red/green wire.
Old 11-12-2014, 02:57 PM
Larry Wall's Avatar
Larry Wall
Ahh thank you! Learning about how diesel engines operate with this 96 f250, had to replace the 'glow plug relay' so far.... I wonder if I could find a picture of this fuel bowl connector on google...thanks for the help!
Old 11-12-2014, 03:05 PM
Larry Wall's Avatar
Larry Wall
Me again...where is the fuel bowl heater located? I'm trying to find the darned thing looking for red/green wire to no avail
Old 11-12-2014, 03:07 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
It is on the driver side of the fuel bowl. The connector in the middle of the three if I remember correctly.
Old 11-12-2014, 03:10 PM
Larry Wall's Avatar
Larry Wall
Where is the fuel bowl located?
Larry Wall's Avatar
Larry Wall
I think I'm golden once I know where the fuel bowl is! =)
Old 11-12-2014, 03:15 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
The large aluminum housing right in the middle of the engine where the fuel filter goes. It has a large round black cap on it.
Old 11-12-2014, 03:18 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
Old 11-12-2014, 03:44 PM
Larry Wall's Avatar
Larry Wall
Got it thanks a bunch!
Old 11-12-2014, 03:50 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
No problem. Hope it helps
Old 11-12-2014, 04:25 PM
Larry Wall's Avatar
Larry Wall
This is what I pulled
Fuel bowl heater plug
Old 11-12-2014, 04:31 PM
ReBilld's Avatar
ReBilld
ReBilld is offline
That's not it. That's the fuel restriction sensor. The fuel heater plug is down lower on the side of the aluminum housing.
Quick Reply: 'Wait To Start' light stopped coming on...
