2000 Excursion vibration from underneath
Old Nov 11, 2014 | 03:17 PM
nadeaa0a's Avatar
nadeaa0a
Hello everyone,
I'm new to this forum as I've just bought a 2000 Ford Excursion 4X2 and i hope i can be an active member here.
As the title says, i noticed a vibration coming from the area underneath and most probably from the transmission/drive shaft area. The previous owner mentioned something about replacing the transmission extension housing bushing multiple times and i thought that this might be the problem.
The vibration is not constant on all speeds, it's more noticeable on low RPMs and disappears when i floor it.
I wanted to buy a new set of bushings and seals for the extensions housing/tail, but i'm a little bit concerned about the housing itself being compromised.
So here are my thought and i need your suggestions:
1- Buy new bushings and hope that the issue is resolved.
2- Buy a new or a reman extension housing.
3- Check the drive shaft as it might be the source of the problem.
What do you guys suggest? has anyone experienced any similar issue before?
Also, when i searched FORD website for the extension housing part number, i ended up with a short part number that doesn't give me the exact extension housing for my application. Can anyone help me with that?
Here is the VIN: 1FMNU40S0YEA31813
and this is the part number form FORD website: 7A039
I really need you help guys and i appreciate your input.
Thanx
Old Nov 11, 2014 | 03:47 PM
jpr38057's Avatar
jpr38057
I would check the driveline first, especially u-joints. I can get you the part # of the extension housing but you will have to get the id tag # off the transmission itself. Your vin doesn't give a good transmission id for some reason. There are three different ones it could be.
Old Nov 11, 2014 | 03:59 PM
JuanHuevos's Avatar
JuanHuevos
I second that on the driveshaft/u-joints. I had this exact problem on another truck years ago and u-joints were the culprit. Good luck
Old Nov 12, 2014 | 10:50 PM
nadeaa0a's Avatar
nadeaa0a
thanks
Thanks guys,
I'm taking the truck to the shop today and have them look at those U joints. Will post results shortly
thanx again
vulcrider
1983 - 2012 Ranger & B-Series
Aug 16, 2016 09:19 AM
Mojosolid
Apr 4, 2016 07:23 AM
akorcovelos
32
Oct 29, 2015 11:11 AM
KH338
Jul 27, 2015 11:00 AM
dave91gt
Jan 9, 2010 06:56 PM
