trans question
Old Jul 17, 2003 | 10:12 AM
shrlyjo's Avatar
shrlyjo
trans question
Hey all, I have a question about the automatic trans in a 92 explorer. Trans worked fine but the hubbys truck got stuck in the field and I pulled him out. Now the trans won't shift right. I can manully go through the gears and they will shift ok but they won't go into gear on their own. If the rpms go way up then it will shift into the next gear. Any ideas and hopefully not a major problem that I can't fix myself. Thanks.
Shirley Jo
Old Jul 18, 2003 | 10:42 AM
jim henderson's Avatar
jim henderson
trans question
Keep in mind I am no expert and there may be a simple adjustment or other explanation.
Did you spend a lot of time at high rpm trying to pull the truck out? Did the engine seem to struggle a lot?
It is possible that you either overheated the ATF or you fried a clutch or two. Either condition could lead to junk floating around in the ATF which could cause a valve to get sticky and not allow normal shifts.
I would check the fluid to see if it is nice and red. If it is pink or brown and or smells burnt you may have a problem. I would then drop the pan and look for lots of sediment that looks like pepper. If you have say more than a teaspoon or so, the clutches may be damaged. You really don't want to see more than one or two bits of metal larger than a grain of rice in the pan.
If you are very lucky, a good fluid change and or tranny flush might fix the problem.
Good Luck. Pulling guy out of a mud bog can be tricky.
Jim Henderson
Old Jul 18, 2003 | 10:45 AM
GR8Diesel's Avatar
GR8Diesel
trans question
This could be an easy fix.
I suspect that the vacuum line has been pulled off the vacuum modulator.
Old Jul 19, 2003 | 07:12 AM
Ponyracer's Avatar
Ponyracer
trans question
Check the fluid level and condition as J. Henderson suggested. If O.K.
Is the O/D light flashing? Get the codes retieved. If no codes.
Inspect the vacuum modulator on the passengers side at the back of the transmission. Pull the vacuum line off and see if there is any tans fluid that drips out. If there is fluid in the line replace the modulator valve and dont lose the little rod that is behind it you will need to use it with the new valve.
